Gas and white smoke from exhaust!!! Help - Honda-Tech
Old 10-18-2010, 09:57 AM   #1
fire_fighter97's Avatar
Default Gas and white smoke from exhaust!!! Help
Hello Everyone,
Im looking for some help my 1990 honda accord is running rough and dripping gas out of the exhaust with some white smoke at an idle. check engine light is on while its runs but when its just in the on position the light turns off. Ive changed the wires 3 of 4 plugs (the last one was a little sticky so i didnt want to force it) and the distrebutor. i havent had a chance to do the timing. Please help calling the tow truck in the next 30 minutes!! I wish i could do the repairs myself but im stumped.....
thanks again,
fire_fighter97 is offline   Reply With Quote
Old 10-18-2010, 01:18 PM   #2
Default Re: Gas and white smoke from exhaust!!! Help
How do you know that it is gasoline?
Is your car using coolant at all? Usually white smoke indicates the car is burning coolant, which would indicate a cracked water jacket/heads or blown head gasket.
chikin pickle is offline   Reply With Quote
Old 10-18-2010, 01:27 PM   #3
Heavy fuel smell coming from the smoke also when you put your hand into the leak it smells like gas 100%. I checked coolant nothing is being burned up or mixing with oil.
Old 10-18-2010, 01:36 PM   #4
Hmmm.
Well I would take a peek at your oxygen sensors. If one of them is falsely indicating a lean condition in the engine the ECU would add more fuel to compensate.
Pull the check engine code. I'm betting it is for your oxygen sensor.
Old 10-18-2010, 02:05 PM   #5
Do you think if a wire was grounded. it would cause the number 1 cyclinder to stay completely open. Thats what the mechanic is saying he wants $400 bucks to fix. He said hes checked the ECU and determined that is the problem. Is this easy to find if thats the problem. Thanks again
Old 10-18-2010, 04:13 PM   #6
What do you mean completely open? As in the valves are not opening? The circuit is open?
That sounds super fishy and vague to me.
Old 10-19-2010, 10:08 PM   #7
The injector is staying open and not being burned in the cylinder and pouring gas down the exhaust along with white smoke. Any help you can send would be appreciated
Old 10-20-2010, 12:04 AM   #8
Umm, well I would check out the injector before looking at the wiring. Injectors can get clogged, or stuck open in certain cases. Try running some injector cleaner through it and see if that helps any. The fuel injectors on your car are switched on when power is applied to them. (As opposed to switching ground devices, which switched on when the circuit is completed by connecting the ground)
So if the wires had shorted to ground the injector wouldn't be firing at all. It is possible for the injector wire to short to another power source, which would cause the injector to remain open. However when left undisturbed there really isn't much chance that would happen. The injector containing a mechanical assembly, the injector itself is much more prone to failure than the wiring connected to it.
Try disconnecting the injector from it's plug. If your symptoms remain the same, you have a stuck/failed injector, especially if you don't have a CEL.
White smoke from exhaust 2kdrift Honda Civic / Del Sol (1992 - 2000) 14 11-18-2010 12:01 AM
light grey smoke from exhaust help crxboi90 Honda CRX / EF Civic (1988 - 1991) 0 09-14-2010 04:25 PM
Help!!!!.....white smoke won't go away. touintegra1 Acura Integra 15 10-06-2008 03:18 PM
holy shit i think im fucked nyteflyte2003 Acura Integra 2 11-05-2004 01:31 PM
White Some At Idle nighthunt6 Honda CRX / EF Civic (1988 - 1991) 5 04-08-2003 02:06 PM
Tags
2009, accord, causing, crx, engine, exhaust, gas, honda, hondatech, injectors, smells, smoke, smoking, whit, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
