Gas pedal loose... how do i fix? - Honda-Tech
Old 05-04-2008, 05:05 PM   #1
VietCloud7's Avatar
Default Gas pedal loose... how do i fix?
there's about an inch of play on my gas pedal... how do i tighten it?
VietCloud7 is offline   Reply With Quote
Old 05-05-2008, 06:27 AM   #2
SpazMan's Avatar
Default Re: Gas pedal loose... how do i fix? (VietCloud7)
Don't know how much help I'll be, but I fixed this on my Volvo... the throttle cable has a threaded screw on the end, and you can tighten or loosen it to lengthen/shorten the cable slightly (to shorten the cable, turn counterclockwise, I think). While the car's off, have a friend tap the gas pedal so you can find the throttle cable.
Ari
SpazMan is offline   Reply With Quote
Old 05-05-2008, 05:59 PM   #3
hondadude's Avatar
The throttle cable needs to have a little bit of slack in it to be sure the throttle plate closes all the way.
If not the TPS mis-reads and the ECU changes timing.
hondadude is offline   Reply With Quote
Old 05-06-2008, 12:56 PM   #4
VietCloud7's Avatar
Default Re: Gas pedal loose... how do i fix? (hondadude)
well it's not like your typical loose gas pedal... even when i'm not on the pedal, it's like about an inch above the normal position. I'm not sure if thats a good description but thats the best way to explain it.
Old 05-06-2008, 05:46 PM   #5
SpazMan's Avatar
I had the same issue. I had to press like 3/4-inch before the gas would kick in. This, in my case, was a stuck throttle body in addition to an over-loose gas pedal. But on Hondas, the TB doesn't foul like Volvos.
Ari
cruise control in an R ITR-965 Acura Integra Type-R 1 11-03-2006 02:06 PM
adjust throttle cabel????stupid stupid question hehe DB8B20asic Hybrid / Engine Swaps 1 10-09-2004 12:25 AM
Gas pedal between shifts? KooK Drag Racing 48 04-18-2003 09:29 AM
loose gas pedal after swap Dorikamu Hybrid / Engine Swaps 8 09-21-2002 09:36 PM
kinda sticky gas pedal(kinda would like to have a normal pedal) zerospooon Honda Civic / Del Sol (1992 - 2000) 5 02-28-2002 05:27 PM
Tags
accord, cable, civic, diy, fix, gas, honda, loose, loosen, pedal, press, slightly, throttle, tighten, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
