Old 03-31-2015, 04:40 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Overview
Print Wikipost
Garage Door Opener Programming
Old 10-15-2007, 09:42 PM
THIRB04's Avatar
Default Garage Door Opener Programming
I have an 04 Accord that has over-head garage door opener buttons on the roof console. I was wondering how to program them as my owners manual was not provided to me when I bought the car. Thanks for your time
joey
Old 10-15-2007, 09:58 PM
YeuEmMaiMai's Avatar
Default Re: Garage Door Opener Programming (THIRB04)
register with http://www.ahm-ownerlink.com/ and look in the FAQ for your car if this dosen't work
1. If your door opener is > 10 years old, it may never work.
2. If your opener is relatively new, you should be OK. Start by clearing all existing codes. Hold down 1st and 3rd buttons for 20 seconds, I think.
3. Follow the basic programming procedure - unplug opener, hold remote up to HomeLink buttons, press remote button, press selected HL button, hold both for 5 secs.
4. Repeat 3.
5. Plug opener in again and see if it worked - for older doors w/o rolling code, it should work.
6. If it doesn't work, you probably have rolling code. Find the programming button on your opener motor unit and press it until the light comes on. You might have to remove the light cover to get at the button.
7. Run like an idiot to your Pilot and press the HL button you are trying to program - hold for 5 seconds.
8. Repeat step 7. 2 more times to be safe (without running - you should be there already )
9. Wait about 30 seconds or untill the programming light on your opener goes off, then try the HL button to see if it works.
NOTE: The key with rolling code is that the remote control programming (2. through 5. above) still has to be done before the rolling code opener motor unit programming (6. through 9.). Both must be done in order to get it to work properly.
10. If it still doesn't work, check the Home Link web site for compatibility issues with your brand of opener.
11. If all else fails, it is possible HL may be defective - you may have to find a friend with a different garage door to try programming again.
Old 10-15-2007, 11:49 PM
THIRB04's Avatar
Default Re: Garage Door Opener Programming (YeuEmMaiMai)
thanks! The garage works but the front gate wont program. Oh well, don't know what else to do,
Joey
darrell111
01-07-2013 07:42 AM
richman11
12-31-2012 09:03 AM
Grip
Acura TL, RL & ZDX
08-13-2008 07:17 PM
stockcivic103
12-08-2005 09:30 PM
Quick Reply: Garage Door Opener Programming
