G23 build
Old 08-19-2009, 10:50 AM
New User
JDMInsaneRacing's Avatar
Default G23 build
Pretty much I've been researching "G23" engine builds (H22a4 head w/ F23a1 block) and I want to swap an H22a4 head on my F23a1 99' accord. Durring these other builds pretty much all of the components were taken from scratch and what my question is that since I already have the F23a1 will most of my stock components be compatible with the new head like the pulleys, belts, water pump, sensors and the ecu or am I going to need to swap some parts?
JDMInsaneRacing is offline
Old 10-31-2009, 09:40 AM
jhhj332007's Avatar
Default Re: G23 build
Im trying to do this swap too i gues nobody answering where going to have to do some trial and error.
jhhj332007 is offline
Old 10-31-2009, 11:31 AM
jhhj332007's Avatar
...but i would assume that anything on the block would stay on the block same for head but not sure have you checked out the import tuning magazine they have the complete swap step by step. Check out the website i think they have all info you need. Hit me up when you do the swap
Old 10-31-2009, 12:16 PM
JDM_CD7's Avatar
Use the search feature.
There's a lot of write-ups for the g23 builds
JDM_CD7 is offline
Old 10-31-2009, 02:10 PM
twkdCD595's Avatar
Check out the Hybrid forum here for some thread on G23 information and builds, there is a couple good ones. Tons of information in them.
twkdCD595 is offline
Old 10-31-2009, 02:22 PM
bsivoljr's Avatar
And god created bananas...
Here
http://www.importtuner.com/tech/impp...dge/index.html
I said fk it and went with the TSX option. More efficient option in my oppinion. Im sure the additional attention would eventually equal a Kswap. And probably sooner than later
bsivoljr is offline
Old 11-04-2009, 12:59 AM
extralargenog's Avatar
Need H22 :
Head
Head gasket
Crank Timing gear
H22 water pump gear pressed onto F water pump
and some hondabond.
I have a head and crank gear available :O) CHEAP PM me
extralargenog is offline
k2wenty
08-06-2008 04:02 PM
remo
12-21-2005 07:36 AM
GTibunny16v
12-20-2005 08:24 PM
preluderider
09-14-2005 10:14 AM
integral94
06-02-2004 08:33 PM
Quick Reply: G23 build
