Fuse with different Amp
Hi!
Recently the fuse for 'radio-cigarette lighter' of my car blew up when I was used a cell phone charger in the cigarette lighter. It probably blew up because there was another wire (a wire for woofer) somehow attached to the fuse-socket from outside. Also, I pushed and held my cell phone charger for a few seconds in the socket. I think the fuse got overheated then. So, what I have done now is I've put a 20A fuse in the fuse-socket that requires only a 15A fuse (meant for radio-cigarette lighter). I believe I can now easily use my woofer (which I think is not connected in a right way. But I'm fine with the way it is), radio and the cell-phone/laptop charger easily at the same time. I hope it doesn't create any problem with my chargers.
Kindly let me know if I did something wrong by doing this.
Thanks for your help!
p.s. The model of my car is Accord 97.
Regards
AdventurousDude
Regards
AdventurousDude
Re: (TheMuffinMan)
Agreed. Double check and/or fix your woofer wiring. If a fuse keeps popping, it means that something is wrong and you're being protected from fire, not "time for a bigger fuse."
