will v-tec fit onto an ES3???
i have an 85 accord sei with the ES3 1.8, i want to put single overhead cam v-tec onto it...... is it possible? if so what year and engine do i need to get the head and other parts?
Re: (G2IntegraGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2IntegraGS »</TD></TR><TR><TD CLASS="quote">SOHC vtec is know as vtec-e. As in emmisons. They arent performance heads anyway. </TD></TR></TABLE>
first of all before you post why dont you look up the information you are posting about before you make yourself look stupid again. VTEC-e is a variety of SOHC VTEC just like i-VTEC is a different variety of DOHC VTEC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOV »</TD></TR><TR><TD CLASS="quote">SOHC VTEC implemented for power is often mistaken as SOHC VTEC-E which is implemented for economy. It is worthwhile to note that the 1.5l SOHC VTEC-E used in the JDM Honda Civic ETi produces 92ps. This is in fact less than that produced by the standard 1.5l SOHC engine's 100ps which uses dual Keihin side-draft carburettors. SOHC VTEC in the D15B produces 130ps. This is 30% more than the standard SOHC implementation !
Why dont you read this before you go off spouting information like you actually know anything when you know nothing
http://asia.vtec.net/spfeature/vtecimpl/vtec1.html
As for the original poster no you cant put a vtec head on your motor your best bet is to probably stick a b series in your car if you want some performance. A b series shoudl fit as the first gen integras were roughly based on your car and they had the b series in them in non-vtec trim.
1 Post
Re: (G2IntegraGS)
thats only the vtec on the HX motors...its like a 3 stage deal, and has 2 vtec selnoids
Re: (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi »</TD></TR><TR><TD CLASS="quote">thats only the vtec on the HX motors...its like a 3 stage deal, and has 2 vtec selnoids</TD></TR></TABLE>
VTEC-e is different then 3 stage vtec. only 3 stage vtec has 2 solenoids and the Civic HX does not have that (I should know I used to have one). If I remember correctly all the 7th gen civics had vtec-e in them except for the civic si of course. Also vtec-e doesn't mean emissions it stands for economy, in fact the lean burn the the d series vtec-e engines do actually causes more emissions but it does significantly improve fuel efficiency
Re: (fw190bvi)
92-95 civic vx motors had vtec-e also...but as stated above, completley different than 3 stage vtec motors....
Re: (momstaxi)
well i dont know **** about a honda this old that is why i was asking. what about an older prelude engine, i know that the rear disk brakes of an 83-84 lude will bolt on to my car with new lines... will the engines bolt to my tranny? what engine will? im sorry for the dumb questions but im new at the honda thing, im a 4x4 guy and a drag racer, i dont know very much about hondas. thanks for any help you can give me, i appreciate it.
Re: (85ES3)
Your in a new world man...
It takes a lil bit to get adjusted to.
If you wanting any performance, you have the wrong car. Just drive it around and get good gas mileage and haul stuff.
If your wanting performance out of the box, your gonna have to dump some flow for a prelude or an Integra.. and even then your still high 14's, low 15's.. which is decent. I love my GS-R.
Otherwise, your gonna have to go turbo or nitrous, which I dunno if I'd do either w/your lil engine.
Your better off with swapping the whole thing out for a B series as someone mentioned above or buy another car. But the 2.2 SOHC VTEC head will not fit on your 1.8 Block.
Re: (NAiL05)
the thing is i want to use the 85 because i dont see them...i dont want to be like evrybody else. will an later 80s engine bolt up to my tranny? or even a 90s? what engine will? and if i swap out the engine and tranny will my axels still work or will i have to get custom ones made?
