FLASHING Maintenance Required Light
Old 03-09-2004, 11:41 AM
Acc99ord's Avatar
Default FLASHING Maintenance Required Light
Okay, here's the deal. Yesterday when i turned my car on, the Main'd Req'd Light started blinking about 6 times and then went away. This has not happened before (at least i'm pretty sure it hasn't). I know how to reset the light but i just want to know why it would flash like that. Any info is much appreciated. BtW, it's a 99 Accord V6 Coupe.
Old 03-09-2004, 11:45 AM
.bagged's Avatar
Default Re: FLASHING Maintenance Required Light (Acc99ord)
Was it right as you started the car or had the car been on for a bit?
Old 03-09-2004, 11:48 AM
Acc99ord's Avatar
Default Re: FLASHING Maintenance Required Light (baGged93aCcord)
As soon as i start the car, it flashes and then it goes away. It didnt do that before and i havent made any recent changes as far as engine work or maintenance.
Old 03-09-2004, 11:54 AM
.bagged's Avatar
Usually those are triggered by milage. as a reminder for oil changes.. when was the last change?
Old 03-09-2004, 11:57 AM
Acc99ord's Avatar
oil was changed about 6,000 miles ago
Old 03-09-2004, 12:03 PM
.bagged's Avatar
Thats probably it
Old 03-09-2004, 12:08 PM
Working
-RedneckDave-'s Avatar
That light goes off every 7500 miles and to reset it follow these steps: with the car off push and hold the reset buttom on the cluster then continue to hold and turn the key to the on position and hold until the light turns off and then it is reset. I believe that is right.
Old 03-09-2004, 12:12 PM
.bagged's Avatar
Default Re: FLASHING Maintenance Required Light (01accordv6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01accordv6 &raquo;</TD></TR><TR><TD CLASS="quote">That light goes off every 7500 miles and to reset it follow these steps: with the car off push and hold the reset buttom on the cluster then continue to hold and turn the key to the on position and hold until the light turns off and then it is reset. I believe that is right.</TD></TR></TABLE>
Funny thing is you already had to post that answer today...
Old 03-09-2004, 12:16 PM
Working
I know, but i am trying to be a good sport and not get pissed when people do not search before they ask.
Old 03-09-2004, 12:17 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01accordv6 &raquo;</TD></TR><TR><TD CLASS="quote">I know, but i am trying to be a good sport and not get pissed when people do not search before they ask. </TD></TR></TABLE>
Once the FAQ get finished that should help a little..
Old 03-09-2004, 12:24 PM
Acc99ord's Avatar
i know that the light goes on because it has gone on before and i've reset it before. i just dont know why it was flashing becaue it has never done that, it only stays on.
Old 03-09-2004, 02:38 PM
TOAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acc99ord &raquo;</TD></TR><TR><TD CLASS="quote">oil was changed about 6,000 miles ago</TD></TR></TABLE>ewww
Old 03-09-2004, 02:47 PM
Riceburner247's Avatar
You might want to get that stuff changed, kid.
Old 03-09-2004, 03:06 PM
Acc99ord's Avatar
Default Re: FLASHING Maintenance Required Light (riceburner247)
i know its been a while but in the owners manual it says to change it about every 7,500 miles. the car has about 34k miles on her.
Old 03-09-2004, 03:10 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acc99ord &raquo;</TD></TR><TR><TD CLASS="quote">i know its been a while but in the owners manual it says to change it about every 7,500 miles. the car has about 34k miles on her. </TD></TR></TABLE>
WhAt...every 7500...more like every 3000
Old 03-09-2004, 04:00 PM
jwogen1's Avatar
wow, i would love to see 6k oil--black as night
Old 03-09-2004, 04:01 PM
KGAccord's Avatar
if you would have read a little further it would say that under severe conditions ie. stop and go driving and other scenarios which basically mean how 90% of the people in this country drive their car to change it more frequently.
also if you read even more into the owners it would explain the whole maintenance light thing and tell you how to reset it.
Old 03-09-2004, 07:47 PM
Working
Default Re: FLASHING Maintenance Required Light (KGAccord)
The reason it is flashing is because it is getting close to the time to reset it. It does state in the owners manual to change every 7500 miles but i would not suggest following that. Also i would suggest you change the trans fluid sump everytime you change the motor oil because it will help your trans last a lot longer. Just my tips.
Old 03-14-2004, 04:14 PM
z4hokie's Avatar
Hi. Tried this on my 2003 Accord V6 sedan but no luck. Did the reset procedure change on the '03 model?
Old 03-14-2004, 07:23 PM
Working
Default Re: FLASHING Maintenance Required Light (z4hokie)
Please read your manual, and you will find your answer.
Old 03-15-2004, 05:40 AM
z4hokie's Avatar
The reset procedure only works when your headlights are turned off. Turns out I had my headlights on, using the auto-off feature and that was the problem.
Old 03-31-2004, 02:33 AM
hondafreak2's Avatar
did you get it changed?
ChangT
10-03-2012 09:32 PM
kloscivicsi
Honda S2000
03-30-2007 05:05 PM
pacpark4
05-15-2005 09:59 AM
sharkey65a
08-12-2003 11:08 PM
InfamousRS
09-20-2001 10:57 PM
Quick Reply: FLASHING Maintenance Required Light
