Flashing Maintenance Required Light - 2000 accord
Old 05-25-2004, 01:14 AM
joker8415's Avatar
Default Flashing Maintenance Required Light - 2000 accord
i started my car this morning and my maintenance required light started flashing about 10 times or so - i dont have the car manuel as i just bought this car a couple weeks ago...any cause for this?
Old 05-25-2004, 06:25 AM
Phaulkyou's Avatar
Default Re: Flashing Maintenance Required Light - 2000 accord (joker8415)
That light is milage timed, you need an oil change.
That is all.
To reset it, put the key in, push the trip odometer reset button, turn the key for a few seconds, like you are going to start the car, (if its a 5sp, DO NOT push the clutch) You dont want the car to actually start. If you have an auto, i am not sure what to do.
Old 05-25-2004, 07:41 AM
Heat's Avatar
Default Re: Flashing Maintenance Required Light - 2000 accord (Phaulkyou)
That light starts flashing after 6,000 miles after the last reset, I believe, and stays solid after 7,500 miles. Something like that.
But yes, it's a reminder to do routine maintenance, to reset it just follow the instructions above (it should be the same for an automatic as it is for a manual).
Old 05-25-2004, 01:19 PM
joker8415's Avatar
Default Re: Flashing Maintenance Required Light - 2000 accord (Heat)
thanks for the tip, i just got my oil changed so it might need to be reset
Old 05-26-2004, 05:49 AM
Heat's Avatar
Your car may need more than just an oil change, check your manual for the maintenance schedule. If you don't have your owner's manual, tell us the year and how many cylinders and we can tell you what the factory recommends.
Old 05-26-2004, 10:15 PM
joker8415's Avatar
2000 honda accord v6 vtech - bout 76000 miles
honda4life03
11-14-2017 04:31 AM
slo2k
Honda S2000
01-27-2010 05:53 PM
bbyxme
03-15-2008 09:44 PM
kloscivicsi
Honda S2000
03-30-2007 05:05 PM
lx98
04-27-2003 10:13 PM
Quick Reply: Flashing Maintenance Required Light - 2000 accord
