Old 04-06-2015, 10:04 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
fan will not turn off and killed my battery overnight
Old 01-02-2009, 07:53 AM
mark2583's Avatar
Default fan will not turn off and killed my battery overnight
ok for starters i searched but could not find this specific problem. I woke up this morning to a completely dead battery and i suspect that it is due to my condenser fan since when i got home last night and shut the car off the fan was still going, i paid no attention to it because these cars are notorious for having the fan run a few minutes after they are shut off. After replacing the batt and driving for awhile then turning it off, the fan kept running and i had to remove the condenser fan fuse to make it stop. Since then i've been driving with it in then taking it out whenever the car is not in use. 95 4dr lx 5spd, any help would be appreciated.
I want to fix this little problem before it turns into a big one
Old 01-02-2009, 08:00 AM
redbull-1's Avatar
Default Re: fan will not turn off and killed my battery overnight
It could be a bad radiator fan control module (located under the driver side dash), a bad fan relay, or a bad connection somewhere.
Old 01-02-2009, 08:05 AM
redbull-1's Avatar
I would check the relays first.
Old 01-02-2009, 03:52 PM
Conechaser's Avatar
Relay, happened on my '00 Durango.
Old 01-02-2009, 05:43 PM
mark2583's Avatar
i did hear some clicking noises coming from the condenser fan relay in the fuse box, ill replace that
Old 03-22-2009, 10:08 AM
New User
gsrlvr0101's Avatar
does anyone have the relay information for a 92 integra-gsr. I am having the same issue with my radiator fan which does not turn off. I did in install an aluminum Mishimoto Radiator and new AC fan. However, I did keep the stock radiator fan and that is the one that will not turn off when the car is off. any ideas?
Old 01-20-2010, 10:46 AM
aenigmapro's Avatar
I have the same issue. 92 ls teg. Except, my main doesn't come on, only the secondary. Have no problem overheating but it still bugs me. Mine would stay on all night. I was told that the relay module that sits near the passenger side wheel well controls the main fan. the other relay modules near the driver front headlights control the secondary. I bypassed the sensor by unplugging the sensor, and placing a wire, no more than an inch long, in both ends of the connector. This sends a straight signal to the fan, turning it on. If your fan is good after testing with the battery, try this. On both plugs. They sit behind your motor under the intake manifold. Follow the harness. They should come on with the ignition off. It's also safer than testing with the battery. Try it!
NAS95
01-15-2018 01:51 AM
NVMYDC
07-20-2011 08:06 AM
s2kkk
08-29-2004 10:35 PM
Nos4R2
01-26-2003 09:40 PM
Quick Reply: fan will not turn off and killed my battery overnight
