Fan draining battery
In a Junkyard near you.
Cooling fan timer. It's right behind your glovebox (mounted to the brace just about right in the middle). Pull the glovebox down and you will see the black box. If the fans are running at that moment unplug it and if the fans quit then the timer is bad. (you can't miss the box it says "radiator fan timer" right on it).
dominic11
07-30-2008 01:50 PM
