f22b1 plans and questions
My future goal is to boost so this summer i am going to start working on that. My first step is to have the block sleeved bored and honed to 86mm.
http://bisimoto.com/store/index.php?...roducts_id=148
http://bisimoto.com/store/index.php?...roducts_id=152
In the mean time i'm going to buy this piston rod set
http://bisimoto.com/store/index.php?...roducts_id=311
Alright so some question are does this sound like a good set up to prepare for boost. Are those pistons for the f22b1 because it says f22b so i would assume for all f22b models. Last question is if my head will be fine with my block bored to 86mm until i get the money to have the head done by bisi.
Re: f22b1 plans and questions
There i fixed the links. My next step is to get the head ported by bisi
http://bisimoto.com/store/index.php?...roducts_id=346
Then i will start buying turbo parts such as manifold, Turbo, turbo cams, etc...
im am going to use the f22b1 head but i am gonna have bisi port and refinish the head and will replace springs, cam, etc. i wanna be able to push quite a few pounds.
I just bought that same piston and rod set from Bisi last week, I actually just received the parts today. Those pistons will work for any F22 (minus the F22C which is a whole 'nother beast) as long as your bore is 86, which you already covered.
I hope to have all these plans at least the bottom half done by the end of summer. Can say goodbye to all my paychecks.
and Jax what did that piston kit all involve. Does it come with pins and rings?
To check out a few pics of the kit use this link: https://honda-tech.com/forums/showth...2820222&page=2
Not trying to steal your thunder just thought you might wanna see a few pics.
