f22b or???
Old 08-26-2011, 04:38 AM
accord 2 door's Avatar
Default f22b or???
i think i have the f22b but am not sure its single overhead cam non vtec in a 1994 accord lx 5 speed. anyone know what it would be and did the f ever come with vtec???
Old 08-26-2011, 04:47 AM
1991civiclx13's Avatar
Default Re: f22b or???
your engine is the f22b2 SOHC with no vtec, and yes some f's have vtec
Old 08-26-2011, 07:31 AM
ok my next question is that i work with a guy who has a 1997 accord and said he would give me the motor out of the car for free cuz it was beat up in a accdent............he clams that it has vtec but is a single overhead cam motor so what what motor whould that be and woud it bolt up to my tranny as is????
Old 08-26-2011, 08:54 AM
Mister T's Avatar
That's the F22B1. It's the same engine, with VTEC. It'll drop right in but you will have to make the necessary changes to the wiring/ECU to get the VTEC working. You're only going to gain something like 15hp if more power is your goal.
Old 08-26-2011, 09:04 AM
CDelgado220's Avatar
If it's free and a better shape engine I would store it as an extra or even sell it later after a few fixes if it needed it
Old 08-26-2011, 09:08 AM
He knows where you live!
TheMuffinMan's Avatar
Bingo, I'd take it to sell.
It's OBDII and VTEC, so you'd have to do some wiring and hardware swaps to get it to work - if you're asking what kind of motor and not sure if an Accord came with a VTEC motor you probably don't want to do that work yourself.
Old 08-26-2011, 10:19 AM
the ecu and computer comes with it!
Old 08-26-2011, 10:38 AM
That's fine and dandy, but you will still have:
1) Add the additional required sensors (and wiring) to your car
2) Purchase an OBDI to OBDII conversion harness for the ECU
3) Hope it all still works and wasn't damaged during accident/swap
And depending on whether it was automatic or manual, work with that as well. IIRC 96/97 had the TCU integrated into the ECU. 94/95 had a separate TCU.
Old 08-26-2011, 12:03 PM
lethalaccord's Avatar
one question. If you have a obdII non vtech motor but want a obdII vtech motor, you'll have to get the necessary wiring and ecu?
Old 08-26-2011, 12:32 PM
how much work is it going to be????
Old 08-27-2011, 02:44 PM
nus_dogg's Avatar
Yes for the wiring and ECU. Because you'll need to wire up VTEC Pressure Switch & VTEC Solenoid. Also, you'll need the VTEC ECU for the F22B1 to run correctly. The F22B2 ECU will work but will throw codes and it won't be running at it's full potential and I suggest not to go that route.
Old 08-28-2011, 03:59 PM
GhostAccord's Avatar
Easy work, not much too it at all. I can do it in a weekend! 20hrs, maybe less, depends on how many people stop buy and how many beer I drink Now for someone with absolutely no experience (obvious) this could take quite a bit of work and a lot of time. Not something you want to tackle yourself if this is your daily driver and you need it by the end of the weekend.
Ya know what, I hate to be that guy that comes in that seems to be offering no help and just says to do a search. However, with 73,473 threads in this Accord section and an FAQ with well over 100 links, no one should have to be that person.
Happy reading! After your done doing some more research there are always people around to help out with any specific issues pertaining to swaps.
PS if you can get your buddy to throw in the complete OBDII wire harness it might be worth the time to swap. Other than that, take the motor and sell it!
Old 08-28-2011, 05:23 PM
cyotani's Avatar
It took me 2 weekends to get my swap running. and thats with also doing the clutch and flywheel as well a new head gasket, seals and timing + balance belt (which I would recommend you change if you decide to swap it in because its easy when the motor is out) and many small things going wrong. with all that the motor should be golden for the next 50,000+ miles.
That was the first time every doing a motor swap and now that I have the experience I can do it in a weekend. if you go through with it find a friend that knows how and pay him some cash. A shop will charge you alot.
Floyd91
15
04-14-2020 09:51 PM
jonina
07-26-2012 09:02 PM
MyLilHatch
04-10-2006 11:58 AM
CD7Accord97
06-01-2005 11:54 AM
b16 matt
10-04-2003 03:05 PM
Quick Reply: f22b or???
