F22 engine specs needed asap - Honda-Tech
Old 01-03-2003, 07:52 PM   #1
BoostedH23a1's Avatar
Default F22 engine specs needed asap
i need the specs for the f22 non vtec and the f22 vtec just like this website has
http://raceseek.com/honda_specs.htm
BoostedH23a1 is offline   Reply With Quote
Old 01-03-2003, 10:07 PM   #2
Default Re: F22 engine specs needed asap (BoostedH23a1)
One2chi is offline   Reply With Quote
Old 01-09-2003, 06:04 AM   #3
Default Re: F22 engine specs needed asap (5thgenaccordian)
no thats not what i mean.. i need like rod dia. sizes, crank specs... **** like that. mainly for the F22 vtec. im gonna build my H23 and i hear f22 crank is the same..not sure bout the vtec though.
Old 01-09-2003, 07:49 AM   #4
niedejb's Avatar
Ive got a f22b1 crank out... Tell me what you want and I can measure it.
niedejb is offline   Reply With Quote
Old 01-22-2003, 11:33 AM   #5
Default Re: F22 engine specs needed asap (niedejb)
do u have a micrometer.. if so measure the diameter or the rod jorunals and the main journals..
Old 01-22-2003, 11:38 AM   #6
GZERO's Avatar
I'm interested in this as well
GZERO is offline   Reply With Quote
Old 01-22-2003, 11:48 AM   #7
FastechAccord's Avatar
H23 and F22B1 rods are interchangeable, right?? I need to know for my buildup. The block leaves for Golden Eagle monday.
FastechAccord is offline   Reply With Quote
Old 01-22-2003, 01:19 PM   #8
Default Re: F22 engine specs needed asap (EvoAccord)
thats what i hear but i just wanna make sure.. hell if u need some rods i have some.. pistons are still on them though
Old 01-22-2003, 02:20 PM   #9
niedejb's Avatar
Unfortunately, now that I see the reply the crank is at the balancer.
But...from the OEM manual f22b1
Journal 1&4 : 49.984-50.008
2: 49.976-50.000
3: 49.972-49.996
5: 49.988-50.012
Taper (.005 max), O/R (.005 max), end play .10-.35, runout .030 max
Rod Journals :47.976-48.000
I'm a metric guy so these arent inches
Post if the H crank is the same
Old 01-22-2003, 04:02 PM   #10
New User
Gennady's Avatar
Gennady is offline   Reply With Quote
Old 01-22-2003, 04:21 PM   #11
Default Re: F22 engine specs needed asap (Wont be beat)
beatiful.. thanks
Exhaust Sale, Invidia, Greddy, HKS, Tanabe, Megan Racing, Tsudo Honda Gen Performance 38 05-15-2009 06:42 PM
SPECS of camcard for mazworx V1 IPG turbo cams alexsracing Drag Racing 5 05-31-2008 08:02 AM
F22 aftermarket cams! AccordSleeperZzZ Honda Accord (1990 - 2002) 9 09-29-2006 12:53 PM
where can I find a H22a spec sheet? djnikko Honda Prelude 4 05-28-2005 10:10 AM
Opinions of this ECU please :) poid Tech / Misc 2 02-26-2003 03:03 PM
Tags
22cl, 94, crank, engine, f22, f22a, f22b, f22b1, honda, interchangeable, max, motor, prelude, rods, spec, specs, whp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
