F21A Rear Balance Shaft Question
While changing my timing belts on my 1993 Honda Accord EX(JDM Engine) F21a I failed to install the rear balance shaft holding tool through the maintenance hole before removing the belt. Susequently the rear balance shaft rotated.
Can I just line up the rear balance shaft through the maintenance hole with the bolt realign the front balance shaft with it's alignment marks and install the timing belt?
I see what looks like a indentation on the rear shaft pully front and a notch on the pully aft edge they are just short of 180 degrees from each other. Do these marks have to line up some where before I install the aft shaft holding tool?
Thanx!
Thanx!
tweaked.crx
11-06-2012 06:55 PM
