F20b specs?? - Honda-Tech
F20b specs??
Old 06-21-2007, 08:21 PM   #1
hahaha38's Avatar
Default F20b specs??
Well what I want to know are some specs.Anybody played with them?? Id like to know the rod length. piston skirt length with where the rod bushing goes. Whats the throw on the crank?Like what size are the mains and rods. Int/Exh valve sizes. What are the stock cams ground at. And thats all I can think of for now.Thanks for any help in advance guys.
hahaha38 is offline   Reply With Quote
Old 06-22-2007, 03:53 PM   #2
Loco-B's Avatar
Default Re: F20b specs?? (hahaha38)
those are some good questions.
i've got a few good answers. This info was taken from a Japanese repair manual I have for the JDM/UKDM 5th Gen CF chassis Accord.
deck height = 8.643
bore = 85mm/3.346
Cylinder Head
combustion chamber volume = 53.8cc
intake valve dia. = 34mm
exhaust valve dia. = 29mm
head gasket bore = 86mm
head gasket thickness = .026
pistons
piston dia. = 85mm/3.346
compression height = 1.221
wrist pin dia. = .866
Crankshaft
stroke= 88mm/3.464
main journal dia. = 55mm
rod journal dia. = 1.771
rods:
length = 5.709
width = .935
be bore = 1.890
pin bore = .8649-.8654
Modified by LocOBanAnA at 2:20 AM 6/23/2007
Loco-B is offline   Reply With Quote
Old 06-22-2007, 08:18 PM   #3
hahaha38's Avatar
Wow thanks for the info thats exactly what I was looking for.
Old 06-22-2007, 08:19 PM   #4
Loco-B's Avatar
Default Re: (hahaha38)
Old 06-22-2007, 09:12 PM   #5
hahaha38's Avatar
Hay would you happen to know the compression height of an f20c would you?? Or would you be able to point me in the direction of where I could find that info?
Old 06-22-2007, 10:28 PM   #6
machine4321's Avatar
search in the lude forum ...there is a h/f faq thread i forget whats the title is but it may have it in there ...
so what the plans for your f20b
machine4321 is offline   Reply With Quote
Old 06-23-2007, 12:25 AM   #7
Loco-B's Avatar
Default Re: (machine4321)
i dont think there are any listing for the F20c in that thread.
just the accord f22's, f20b, and the h22's.
Quote:
yeah....go to your local bookstore. Locate a chiltons, or haynes manual for a s2000. Most of those repair manuals have specs from the factory printed. If your trying to get info for Japanese motors you might have better luck trying to find an importer here in the states to get you a repair manual from overseas.
Old 06-23-2007, 02:53 PM   #8
hahaha38's Avatar
Ive pretty much looked through all the threads on specs in here. Mainly they show hp and tq specs. What im thinking of doing is a f20B with 6.0 length rods special pin location and compressin height. So with 25+ pounds of boost I want 550 at the wheel with about a 12k redline. Ive already found some body that will make me the parts I just need the specs. But yeah thats the plan atleast.LOL. And thanks again for the info ill just keep looking for the rest.LOL
F22c Rod Length vinuneuro All Motor / Naturally Aspirated 2 07-09-2008 08:01 AM
K24 specs? TREVER All Motor / Naturally Aspirated 6 12-12-2003 04:35 PM
D17A engine specifications HondaChevy Acura TL, RL & ZDX 1 07-25-2003 08:11 AM
gsr rod length vs. ls rod length hi-Powered Acura Integra 2 04-26-2003 12:37 PM
H22a specs? KS-R Honda Prelude 9 01-26-2003 07:26 AM
Tags
2001, bolt, civic, exhaust, f20b, honda, hp, manual, motor, pics, repair, rod, size, spec, specs, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
