f20b - Honda-Tech
f20b
Old 11-24-2005, 10:55 AM   #1
camelspit's Avatar
Default f20b
was wondering, would the f20b be a relatively easy swap on a 95 accord?
thanks.
camelspit is offline   Reply With Quote
Old 11-24-2005, 12:33 PM   #2
Banned
Default Re: f20b (camelspit)
yes
jakeiscool is offline   Reply With Quote
Old 11-24-2005, 01:39 PM   #3
HondaMike17's Avatar
Default Re: f20b (JakeIsCool)
im pretty damn sure it would bolt right up my man, good luck
HondaMike17 is offline   Reply With Quote
Old 11-24-2005, 01:48 PM   #4
Banned
why not an h22 for 1900 bucks?
Old 11-24-2005, 02:24 PM   #5
camelspit's Avatar
well i want to do something different. f20b is 200hp, 145 tq. h22 just has more torque, but weighs more (i think). and yea h22 has more aftermarket support, but thats because everyone and their mother has an h22. or a b series so. thus i choose f20b.
Old 11-24-2005, 05:55 PM   #6
hondabum's Avatar
ya i would look into boosting the f20 that would be cool
hondabum is offline   Reply With Quote
Old 11-24-2005, 06:18 PM   #7
momstaxi's Avatar
Default Re: f20b (hondabum4life)
an h22 doesnt weigh more than an f20b...and if it did it would be +/- 10lbs or so...
momstaxi is offline   Reply With Quote
Old 11-24-2005, 07:52 PM   #8
CWestAccord's Avatar
Default Re: f20b (momstaxi)
F20B is nearly IDENTICAL to the H22. same weight, but higher horsepower, and less torque. I forget the figures, but If you can put an H22 into a CD Accord, then you can put in a F20B. the main swap issue to remember is that all F20Bs were OBD2.
The F20B was made for the 6th gen Accords, so Honda had a valid contender in the Touring Class in road racing, where the engine size is limited to 2.0 liters, where the H22 is oversized. All Honda did was use a H22A-TypeS motor, de-stroke it, and put it in the Accord. same bore, but I'm not sure about compression ratio, but I know it's higher than the JDM H22A's 10.6-1. same TypeS cams, too.
CWestAccord is offline   Reply With Quote
Old 11-24-2005, 08:45 PM   #9
momstaxi's Avatar
Default Re: f20b (CWestAccord)
wasnt one of the main purposes of frm sleeves was to make the engine block less weight?
Old 11-24-2005, 09:50 PM   #10
Banned
Quote:
no, the frm sleeves help with keeping heat down. weight could have been part of it but i highly doubt it.
Old 11-27-2005, 06:07 AM   #11
CD7-F20B's Avatar
i wish you alot of luck on that swap.. it took me on my swap 4mnths...
my advice to you is to go obd 1..
CD7-F20B is offline   Reply With Quote
Old 11-27-2005, 07:10 AM   #12
Banned
Default Re: f20b (CD7-F20B)
4 months? Atheist had my f22 out and my h22 in next day. Im assuming it was the wiring that was giving you trouble.
Old 11-27-2005, 07:51 AM   #13
CD7-F20B's Avatar
wiring is a headache..
it was 4mnths cause i worked on it every other weekend.
but it worth all worth it..
the only prob i have now is a stuck IACV needs to replaced.
ive gone through 2 ecu already P05, P13, and now i have a chipped P28
Old 11-27-2005, 10:17 AM   #14
MestizoRacer310's Avatar
I hear you on wiring. I'm still not that keen on wiring jobs....although I do feel like I love lights....I'm thinking of fabbing a removable light pod (and I don't really know exactly why...)
I have that same problem. My rpm's in idle-especially while still cold-lob between 1,000 to 2,000rpm
MestizoRacer310 is offline   Reply With Quote
Old 11-27-2005, 03:57 PM   #15
CD7-F20B's Avatar
Default Re: f20b (MestizoRacer310)
when i finished the swap....
Old 12-01-2005, 03:53 PM   #16
CD7-F20B's Avatar
el bumpo....
Old 12-01-2005, 04:39 PM   #17
fw190bvi's Avatar
why are you bumping this thread?
on a technical note, why didnt you run PS on the F20b
fw190bvi is offline   Reply With Quote
Old 12-01-2005, 06:00 PM   #18
CD7-F20B's Avatar
Default Re: f20b (fw190bvi)
i havent had a chance to buy the prelude crank pulley the F20B crank pulley doesnt have the dual pulley its a single pulley..
Old 12-01-2005, 07:50 PM   #19
New User
Nick H's Avatar
the f20b, h22a, and h23 all use the exact same block...the internals/bore on the sleeves may be slightly different, but you will end up putting an f20b into a 5th gen accord the exact same way as you would put an h22 in...same method, same wiring, same modifications to the wiring and driverside engine mount...
also, that tourque you speak of is much needed in the heavy, fat *** accord...sure it has more hp (5 more than the h22 which you will most likely not even feel), but realize that the hp rating is taken from the lofty 8000 rpm area...the tq rating is also taken from right around the vtec engagement, but you need to look at the power production down low and across the entire rpm range between the two motors...having a motor with a little extra tourque in the low rpm's will make daily driving much nicer and responsive...good luck if you wish to do this, but realize that an h22 could be purchased for much less and modified with the extr money you are putting out for the f20b...and if you are going to moderately modify the f20b anyways, then it's utterly pointless to use it as a platform anyways...
Nick H is offline   Reply With Quote
Old 12-02-2005, 05:29 AM   #20
propwdialogue's Avatar
Default Re: f20b (Nick H)
I completely agree. While there is something to be said for being different (and it certainly is a noble goal), you are going to get a lot better results for your money using the H as your base. The difference in price in the two motors could get you a nice start on building your H for turbo
propwdialogue is offline   Reply With Quote
Old 12-05-2005, 01:18 AM   #21
chuckles2's Avatar
Default Re: f20b (propwdialogue)
the f20b has a 85mm bore as apposed to a 87mm bore in a h22a, and the stroke is 1mm shorter.
also has iron sleeves not frm, 11:1 compression, rods are stronger then alot of aftermarket ones for h22a, and the bottom end has very tight tolerances, wicked r/s ratio. it revs like crazy with the right tiuning and mods. much better base the h22a especially if you are not planning on internal mods.
Yes the h22a has more potential but the f20b is much more fun to drive with once you have done a few bolt ons, mugen made 300whp with their f20b in the BTCC.
Also f20b throttle body is 2mm bigger then h22a. all parts are interchangerble with h22a parts except for internal block components and valves, this includes cams manifolds etc.
my JDM accord SiR-T (what the f20b comes from) can drill a cd6 SiR accord with a mildly modded h22a
do you guys have cd6 accords in the states?
chuckles2 is offline   Reply With Quote
Old 12-05-2005, 08:00 AM   #22
fw190bvi's Avatar
Default Re: f20b (chuckles2)
no, accord was never offered with a DOHC motor in the states untill the K24 in the 7th gen accord....
from what ive read, a modded F20b>H22a...but stock for stock, the added torque of the H22a gives it a slight advantage
Old 12-05-2005, 09:33 AM   #23
gaydm.accord's Avatar
couldnt you just get a ps bracket off a 97 lude and used that on the f20 b with f22 ps pump lines etc... kind of like the h22 swap only thing needed is the bracket.
gaydm.accord is offline   Reply With Quote
Old 12-05-2005, 03:13 PM   #24
i_kick_turtles's Avatar
I was just curious as to what ecu the f20b uses? Those IM runners look really short.
i_kick_turtles is offline   Reply With Quote
Old 12-05-2005, 08:03 PM   #25
CD7-F20B's Avatar
Default Re: (I R Tylor)
its a P5 obdIIb..
F20B FAQ problem F20B6THGEN Honda Accord (1990 - 2002) 4 08-18-2012 08:50 AM
f20b member dato Honda Accord (1990 - 2002) 16 04-27-2010 05:25 PM
f20c3 xmrxnguy3nx Honda Accord (1990 - 2002) 1 09-23-2009 06:04 AM
The F20A voiceinurhead05 Tech / Misc 3 01-31-2006 07:17 AM
F20B ecu AccordCF4 Tech / Misc 13 11-18-2002 10:16 AM
Tags
95, accord, cd7, crank, ecu, f20b, h22, honad, honda, hp, iacv, manual, modify, pulley, sir, zealand
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
