Exhaust swap from a 97 EX to a 96 LX?
Old 03-06-2015, 09:43 PM
teletekman's Avatar
Default Exhaust swap from a 97 EX to a 96 LX?
I think from what I have read so far that this should be an exact swap but wanted to ask first to make sure. I am looking to swap the exhaust system from the front flange of the lower mid section converter all the way back to the tail pipe from a 97 Accord EX to my 96 LX. The 97 EX is a 4 door sedan and my 96 LX is 2 door but from what I gathered the length of both vehicles are identical at 185.6". Also I noticed the EX uses the F22B1 V-tech and my LX is the non v-tech F22B2 version. The only thing I have gathered on this is there are some differences with the downpipe between the two models but nothing as far as from the mid section converter on back?
Is there anything that I am missing that would prevent me from doing this or am I correct that this would be a direct swap? I think the EX uses a dual outlet tip vs. my single outlet but that's all I can tell so far. I was also thinking about the location of the pipe hangers as well if that is different.
Thanks for any info...
Sean
Old 03-06-2015, 10:46 PM
holmesnmanny's Avatar
Hondapartscheap.com
Cross reference the part numbers
Old 03-07-2015, 03:43 AM
tim73's Avatar
Default Re: Exhaust swap from a 97 EX to a 96 LX?
Also rock auto has a very detailed drawing of exhaust you can compare the two systems.
Old 03-07-2015, 04:50 AM
GhostAccord's Avatar
From the catalytic converter back is the same length and fit.
Part numbers may differ as the resonator and muffler may be different designs, they will still fit.
Rugbyman
05-21-2017 06:39 PM
BassSlaya
07-09-2009 08:46 AM
kidd_drastic
01-31-2006 09:56 AM
robbo
08-18-2003 07:04 PM
Quick Reply: Exhaust swap from a 97 EX to a 96 LX?
