EXHAUST DIAGRAM - Honda-Tech
EXHAUST DIAGRAM
Old 07-30-2008, 11:55 AM   #1
aln2590's Avatar
Default EXHAUST DIAGRAM
What websites can give me a parts diagram for a 1996 Accord Exhaust?
thanks!
aln2590 is offline   Reply With Quote
Old 07-30-2008, 12:07 PM   #2
bseriescrxsi's Avatar
Default Re: EXHAUST DIAGRAM (aln2590)
this is for a 2 door ex
001 18010-SV4-305 GASKET SET, EX. PIPE A
(No Color) 1 1995 ACCORD
002 18030-SV1-C70 MUFFLER SET, EX.
003 18150-P0A-A12 CONVERTER ASSY.
004 18176-P08-003 BOLT, CONVERTER
(No Color) 3 1995 ACCORD
005 18181-P0A-A00 COVER (LOWER)
006 18182-P6W-A00 COVER (UPPER)
007 18201-SV4-A71 PIPE, EX. MIDDLE
008 18210-SV4-A51 PIPE A, EX.
009 18212-SB2-961 GASKET, EX. PIPE (ISHINO)
(No Color) 2 1995 ACCORD
010 18213-SV4-A31 STAY, EX. PIPE
011 18215-SV4-000 RUBBER, EX. MOUNTING
012 18215-SV4-A70 RUBBER, EX. MOUNTING
013 18215-SV4-A81 RUBBER, EX. MOUNTING
014 18220-SV1-C70 PIPE B, EX.
015 18222-SV4-C31 BRACKET, EX. PIPE MOUNTING
016 18229-SV1-003 GASKET, EX. FLEXIBLE
016 18229-SV4-003 GASKET, EX. FLEXIBLE (50.8MM ID)
017 18229-SV4-A71 GASKET, EX. FLEXIBLE (48.6MM ID)
018 18230-SA0-930 SPRING, FLEXIBLE JOINT
019 18230-SV4-000 SPRING, FLEXIBLE JOINT
(No Color) 4 1995 ACCORD
020 18231-SR3-J01 BOLT A, FLEXIBLE JOINT
(No Color) 6 1995 ACCORD
021 18280-SY8-A00 STAY ASSY., EX.
022 18282-SV1-A30 BRACKET B, FLEXIBLE MOUNT
023 18286-SV1-A30 DAMPER, EX.
024 18286-SV4-300 DAMPER, EX.
025 18287-SV4-A30 STAY, CONVERTER MOUNTING
026 18310-SB0-023 FINISHER, EX. PIPE
027 18393-SH3-S00 GASKET, PRE CHAMBER (52.5MM-53.5MM)
028 36531-P0A-A01 SENSOR, FR. OXYGEN
033 74601-SV4-A01 PLATE, FLOOR HEAT BAFFLE
034 74602-SV4-000 PLATE, CATALYZER BAFFLE
035 74651-SV4-V50 PLATE, TANK BAFFLE
036 74655-SV4-V50 PLATE, MUFFLER BAFFLE
037 90023-PK1-000 BOLT, FLANGE (6X10)
038 90115-659-003 NUT, SELF-LOCK (8MM)
(No Color) 11 1995 ACCORD 0.28 0.21
039 90126-SS0-000 BOLT-WASHER (6X16)
040 90201-P0A-A00 NUT, CONVERTER MOUNTING
041 90212-SA5-003 NUT, SELF-LOCK (10MM)
042 90212-671-005 NUT, SELF-LOCK (10MM)
043 90301-SP0-003 NUT, PAINT CUTTING (6MM)
043 90301-SV7-000 NUT, PAINT CUTTING (6MM)
045 90401-P0A-A00 WASHER, R. CASE (UPPER)
(No Color) 1 1995 ACCORD 6
046 90402-P0A-A00 WASHER, L. CASE (UPPER)
048 91517-SE0-003 CLIP, DASHBOARD INSULATOR (LOWER) (OUTER)
049 93405-06012-08 BOLT-WASHER (6X12)
050 93405-06012-08 BOLT-WASHER (6X12)
(No Color) 8 1995 ACCORD
051 93407-08035-08 BOLT-WASHER (8X35)
052 95701-10020-08 BOLT, FLANGE (10X20)
053 95701-06014-00 BOLT, FLANGE (6X14)
Modified by bseriescrxsi at 3:14 PM 7/30/2008
Modified by bseriescrxsi at 3:16 PM 7/30/2008
bseriescrxsi is offline   Reply With Quote
Old 07-30-2008, 12:16 PM   #3
GhostAccord's Avatar
Default Re: EXHAUST DIAGRAM (bseriescrxsi)
The above image is for an EX Accord. The only real difference between the EX and LX exhaust parts is the dual down pipe #8 and the middle pipe #7. Other than that from teh cat back is interchangeable.
GhostAccord is offline   Reply With Quote
power folding mirror diagram Beau Gotti Honda Civic / Del Sol (1992 - 2000) 3 08-10-2008 03:25 PM
Interior Fuse Box Diagram HaitianEF9 Honda Civic / Del Sol (1992 - 2000) 2 11-06-2007 04:33 PM
valve seats replaceable on ITR head? RTW DC2R Acura Integra Type-R 11 10-13-2005 12:04 PM
anyone have the wiring diagram for apex v tec controller 2? Junkiii Ek Tech / Misc 1 03-24-2005 05:19 PM
Wiring Diagram v-attack Acura Integra Type-R 4 07-21-2004 05:54 PM
Tags
1990, 1995, 95, 97, accord, acura, civic, crv, diagram, exhaust, honda, integra, middle, pipe, prelude, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
