EVAP solenoid valve/flow switch help - Honda-Tech
Old 05-23-2011, 05:38 PM   #1
Default EVAP solenoid valve/flow switch help
New to forum but have probably read 1000 posts so far in the week since I've bought this '96 EX wagon, auto.
Two EVAP pieces were broken when I bought it. The bottom nipple on the "VALVE ASSY., PURGE CONTROL SOLENOID", and the tee that connects the vacuum line from the solenoid to both the canister and the "SWITCH ASSY., PURGE FLOW (A37)". I replaced the tee and epoxied the solenoid nipple back on. The nipple is on there solid with no leaks or obstructions. I'm gratefull for the diagram provided by Dannyvho here:
http://www.htarchive.net/showthread.php?p=40429686
The second PDF (B111), ACCORD 4D 1996 KA LX 4AT, B-1-11 PURGE CONTROL SOLENOID VALVE ('96,'97), is exactly how my evap is plumbed under the hood.
Took it to get emissions and it failed HC by almost double the max (2.25 measured vs. 1.20 max) and CO even worse: 76.4 measured vs. 15.0 max. The emissions test place gave me graphs of the purge rate, CO, and HC, and it looks like the EVAP system is out of control. The car runs fine. Compression is 160psi x 4 @ 5280' altitude...corrected to sea level I think thats around 185psi. New plugs, no misfire, runs very strong. The only thing I've done to the engine is clean out the EGR ports, change the oil, and change the air filter, plus the new plugs. No vacuum leaks at idle. It passed Oregon emissions two months ago (I don't have the readings, just the pass sheet) and Colorado emissions a year ago, but I noticed that the NOx was kinda' high so I cleaned the EGR ports. They were filled solid.
So, thinking either the PO or I screwed up the EVAP system, I thought I'd troubleshoot it using my FSM, but it's for a '94 Accord and it doesn't show the troubleshooting flowchart for how my '96/auto is plumbed. Does anyone have these (I think) two pages that they'd be willing to post? It's an F22B2.
Roader is offline   Reply With Quote
Troubleshooting P1457 Code Todhunter Honda Accord (1990 - 2002) 11 12-09-2016 06:02 AM
Help with 1999 Honda Civic DX Evap system code P01457 Leviatard Honda Civic / Del Sol (1992 - 2000) 6 09-13-2015 05:57 AM
?EVAP Purge Control Solenoid Valve? slamLOWnBANGIN Honda Civic / Del Sol (1992 - 2000) 4 10-16-2010 12:00 PM
Honda Civic Emission Systems: egr, evap and pcv Master23 Honda Civic / Del Sol (1992 - 2000) 6 08-05-2010 09:34 AM
Emission Test Results... briefly explain emission control systems and test results gmoneyef Tech / Misc 3 02-06-2007 01:48 PM
Tags
1998, 96, accord, celanoid, diagram, evap, honda, lx, order, showing, solenoid, switch, swith, vacuum, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
