EVAP 2 way valve location
Old 03-13-2007, 09:12 AM
hecubus's Avatar
Default EVAP 2 way valve location
1996 accord lx 5-speed
I've been looking through the factory service manual an cannot figure out what this once piece of evap equipment is...
near the throttle body is the evap purge control valve, the fuel vapor canister, and some other solenoid looking thing mounted directly on the firewall that is hooked inline to these pieces via vacuum hoses. any idea what this is? & how to test it?
Old 03-14-2007, 03:29 PM
hondadude's Avatar
Default Re: EVAP 2 way valve location (hecubus)
If you could let us know what code you have or the reason you think there is an emission problem it might help.
I sent you an IM about getting the PDF files to you
Old 03-15-2007, 07:43 AM
hecubus's Avatar
Default Re: EVAP 2 way valve location (hondadude)
thank you for the reply, I figured out that it is the evap switch (has 5 volts at close & drops to 0 once any vacuum is applied)
I'm getting code 92; so far the only thing that tested bad was the vapor canister which I replaced...but the error code came back after ~85 miles
Old 01-17-2014, 12:40 PM
RIPTEC's Avatar
I'm not a certified mechanic or anything, but I have a 99 accord EX 2.3L and my 2 way valve looks to be under the car back towards the gas tank right by the charcoal canister and vent shut valve. I actually have to replace my 2 way valve this weekend along with the vent shut valve as well.
Old 02-20-2014, 06:20 PM
gpro's Avatar
I have a 94 accord and it was recommended to replace the EVAP two way valve because I'm getting a fuel smell outside the car when I fill up. The service manual shows how to test it but doesn't show where it's located. I have looked under the car and I don't see anything close to what it shows on the picture (11-127). Do I need to remove the fuel tank to replace it?
Old 02-21-2014, 04:47 PM
Grandhustleman86's Avatar
Yes. It is located on top of your fuel tank. You will need to drop the tank to properly service it (space issues). Should have 2 hoses connected to it. In the below diagram the "2-way Valve" is "number 2". you can zoom in to familiarize yourself with how it looks and what it attaches to it.
http://parts.sonshonda.com/showAssem...rimLevel=12280
D-Atk
08-21-2019 03:35 PM
Doug Winsor
08-26-2015 12:40 PM
hollywood28601
12-27-2010 11:09 AM
tom10e
08-08-2005 03:49 PM
mtfishin
11-08-2004 06:35 AM
Quick Reply: EVAP 2 way valve location
