engine wiring diagram 90-93 accord - Honda-Tech
Old 09-16-2012, 07:23 PM   #1
Default engine wiring diagram 90-93 accord
Im looking for the wiring diagram for my 92 accord. Im showing code 9. CYP sensor. I have a feeling it is not the distributor or the sensor, because it has a new distributor in it and it looks like the previous owner tried to bypass a harness thinking they would find the open circuit. Rather than buying a new distributor, i want to look at the wiring first.
Jimmy21 is offline   Reply With Quote
Old 09-16-2012, 11:39 PM   #2
Default Re: engine wiring diagram 90-93 accord
These sensors need to be protected by shielded wire. You might want to just go to the junkyard and pick up a new wire harness.
Helms sells an electrical manual for your car. It's like $30.
holmesnmanny is offline   Reply With Quote
Old 09-16-2012, 11:56 PM   #3
PMed info
BrotherAli is offline   Reply With Quote
Obd2a to Obd1 Distributor Wiring Diagram? Project H Honda Civic / Del Sol (1992 - 2000) 6 12-30-2010 04:17 PM
Distributor/ignition coil location question, 96 accord Jeul Honda Accord (1990 - 2002) 8 01-13-2010 05:12 AM
Wiring Diagram for a 91 SI (MPFI) distributor? 2fast4udude Honda CRX / EF Civic (1988 - 1991) 3 05-15-2006 10:56 PM
H22 distributor firing order h22a_junkie Hybrid / Engine Swaps 9 04-11-2006 09:49 PM
diagram for 91 accord 91according Honda Accord (1990 - 2002) 7 03-21-2004 04:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
