Engine oil leaking from the transmission??? (Pics inside) - Honda-Tech
Old 10-27-2008, 11:19 PM   #1
supermotothud's Avatar
Default Engine oil leaking from the transmission??? (Pics inside)
A few days ago i thought i had a rear main seal leak on my 96 Accord EX Automatic tranny (170k miles)
I cleaned the bottom of the motor and transmission.
Removed the transmission, and noticed that the inside the transmission housing where the driveplate and the torque converter were...it was clean. No oil leaks no drips, no lines of oil...nada.
So i put everything back together. double checked some more, cleaned some more, and i think i know where my engine oil is leaking from..but why?
The oil seems to be leaking from the part of the transmission where the driveshaft is inserted.
It only leaks on the drivers side of the transmission, and I have included a link to a picture album.
It is coming from the hole where you insert the drivers side drive shaft.
And YES it is engine oil, not transmission fluid.
Is there a seal there? why is it engine oil? could i still have a leaky rear main seal?
[/url]
From the picture...you can see the trail of engine oil leaking out
more pics..
http://picasaweb.google.com/Ro...lLeak#
supermotothud is offline   Reply With Quote
Old 10-28-2008, 05:59 AM   #2
P_Adams's Avatar
Default Re: Engine oil leaking from the transmission??? (supermotothud)
It appears to be leaking from the Output Shaft seal. This can be accessed with the removal of the offending axle. The seal mounts in the transmission / differential case.
P
P_Adams is offline   Reply With Quote
Old 10-28-2008, 06:45 AM   #3
dtapia's Avatar
Default Re: Engine oil leaking from the transmission??? (P_Adams)
Quote:
P
x2 looks like dirty atf. which also can look like engine oil
dtapia is offline   Reply With Quote
Old 10-28-2008, 06:29 PM   #4
hondadude's Avatar
In pic #8 you can see the oil is coming from up above; check dist Oring and oil press sending unit.
If it's a Vtec engine the solenoid is mounted to the head right above that area.
The best thing to do is get a couple cheap cans of spray brake clean, blast down the entire area/back of block etc.
Spray around with Dr Scholls foot powder spray, then go for a drive...recheck
hondadude is offline   Reply With Quote
Old 10-28-2008, 08:30 PM   #5
GDD Member
slomofo's Avatar
Output shaft seal and possibly input shaft/rear main as well.
Maximum parts cost: $30.00
Maximum time to be spent: 3 hours.
Most likely scenario: $15.00 and 45 minutes.
slomofo is offline   Reply With Quote
Old 02-28-2009, 08:13 PM   #6
Default Re: Engine oil leaking from the transmission??? (Pics inside)
Did you ever found out what was really leaking?
Thanks.
Bad_dude is offline   Reply With Quote
Old 09-01-2009, 10:28 PM   #7
New User
I have this same problem and its 100 % motor oil not transmission fluid. just swapped the motor and its leakin freash oil from the same spot
My car is a 94 accord ex auto
cody777 is offline   Reply With Quote
Old 09-02-2009, 03:47 AM   #8
just be careful when replacing the offending seal, nick that new one and you will be at it again.......
YeuEmMaiMai is offline   Reply With Quote
Old 09-02-2009, 11:01 AM   #9
I had the exact same problem on my 95. fresh oil running down the transmission. It was the VTEC or spool valve. remove the three bolts and replace the seals...its an easy, cheap fix. If it was dirty oil then I would look else where. I replaced my axle seals mistakingly thinking its was tranny fluid only...actually I had a mixture of the two...my luck.
Funny, the Honda tech kept insisting it was a cam seal. was suprised when I told them it was a spool valve...seems at the dealer those never leak.
spongecop is offline   Reply With Quote
Old 09-03-2009, 01:43 PM   #10
New User
Mines not coming outta the vtec selinoid its commin from exactly were the tread starters is leakin. I cant tell what it is
DIY: Oil Change (With Pictures) JimmyM86 Honda Civic (2001 - 2005) 78 03-27-2016 09:17 PM
CA FS (SF Bay Area): 1989 CRX Si - JDM ZC - Jackson Racing Supercharged - 10psi jasonb Vehicles for sale 17 01-16-2011 05:11 PM
Oil leak on oil lan where transmission meets...main oil seal? 05foresterxt Honda Civic / Del Sol (1992 - 2000) 12 12-30-2010 04:59 PM
F/S...Thermal Exhaust..Del sol seats..momo steering w/NRG QR....Skunk 2 ...Eg foglights egredspools For Sale 86 02-15-2008 05:30 AM
transmission leak DualCamDan Tech / Misc 3 07-26-2005 07:41 AM
Tags
68, 96, accord, camaro, civic, engine, honda, inside, leaking, oil, output, seal, shaft, spray, transmission, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
