EGR valve situo.
EGR valve situo.
hey guys i have a 91 accord f22a4 and i have a big question my car continues to accelerate once my feet are removed from the gas and clutch meanin the car should decelerate , but this car if im at low rpm 1800 or so n like 4 the car continues to accelerate with the intake open without my foot on the gas.......
would this have to do wit my egr valve????????????
Re: EGR valve situo. (white99CF)
Have you ever replaced the EGR ? Do you have any mods/engine swaps? Records of routine maintenance that has been done recently? That info could be more helpful in the long run.
Check for a vacuum leak. when you pop the hood with the engine running can you hear a hiss from anywere other than the end of the intake? Could be that your throttle cable or throttle valve (butterfly) is gummed up and not able to close all the way. Are you handy with fix'n things? This could be as simple as checking your throttle cable ensuring that it is free from dirt and able to rotate and slid properly. If that's not it try removing the intake tube from your throttle body and give it a few good shots of carb/throttle body cleaner while your car is running. This will clean out some of the gunk (carbon & oil - tar like substance that gets built up around the throttle plate/butterfly.
Re: EGR valve situo. (GhostAccord)
its a f22a4 intake exhaust ngk wires and plugs and ive done the carb cleaner thing a few times and problem still exist also when it does this it does throw a code dont kno which one and how to check but yea it does and yes im very handy at fixing things i do 90% of the work on my car unless tranny or brakes LMAO
smeags
10
07-20-2013 10:22 AM
