EGR Flow Insufficient??
CEL went on and diagnose said P0401 EGR Flow Insufficient
i have a 97 ex 4dr and i wanted to know some common problems that cause this code that maybe i could fix. thanks
H-T Order of Merit
Re: EGR Flow Insufficient?? (lax1089)
Probably have to clean the EGR passages in the intake manifold. Check the Accord FAQ for instructions on how to do that.
Re: EGR Flow Insufficient?? (TouringAccord)
ok so i cleaned the passages and the runner really well using hondadudes instructions and its still throwing the same code. do i need to replace the egr valve?
H-T Order of Merit
Did you reset the ecu after you did this? Or did the code reappear after resetting the ecu and cleaning the egr passages?
well i went to autozone and the guy plugged in the diagnostic thing and got the code. i aksed him to reset it but i dont think he did because as soon as i turned my car on the light came on.
can i do it myself somehow?
H-T Order of Merit
you could try pulling the ecu fuse for a few minutes and see if that resets the ecu. if not you can just disconnect the negative terminal from the battery for a few, that should reset the ecu.
alright pulled the fuse for 20 minutes and put it back in but immediatly check engline light comes on when i start the car. could it be a different part of the egr system trhan the ports?
Re: (YeuEmMaiMai)
alright so i had autozone delete the code so if it comes back on i know its the valve. it looks easy to replace but costs 100 bucks which sucks.
Re: (TouringAccord)
is it true that since the egr concerns emissions (in some way) that i could get it done free at honda (since im under 150k)?
H-T Order of Merit
Re: (lax1089)
the egr valve does have to do with emissions but I don't know how that would get the work done for free at Honda. Do they have some sort of warranty on emission parts for your year/model Accord?
Here is a link to the TSB that outlines the extended emission warranty;
http://members.troublecodes.ne...1.gif
Re: EGR Flow Insufficient?? (hondadude)
about a month before i started having problems with the egr i brought my car in for the emissions tune up (plugs, wires, filters, dist cap). does that void me from getting a free repair? i called them today and asked about the extended warranty and they just said..no.
Atomic646
12-16-2012 08:05 PM
businessmanph
01-04-2006 08:36 AM
