effects of altitude on acceleration?
Old 01-31-2007, 06:34 PM
dakers01's Avatar
Default effects of altitude on acceleration?
1995 Accord EX: 2.2L(2156cc), F22B1, MPFI, SOHC 16-valve (Canadian:EX-R)
question: i just moved from a low altitude region to denver, colorado. what adjustments can be made so that my car isn't so sluggish when accelerating?
thanks!
Old 01-31-2007, 07:56 PM
hondadude's Avatar
Default Re: effects of altitude on acceleration? (dakers01)
There shouldn't be any need for adjustments because the barometric pressure sensor is supposed to know the difference, and tell the ECU to wise up to the higher altitude.
Old 01-31-2007, 08:12 PM
K24xCM5's Avatar
Default Re: effects of altitude on acceleration? (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">There shouldn't be any need for adjustments because the barometric pressure sensor is supposed to know the difference, and tell the ECU to wise up to the higher altitude.</TD></TR></TABLE>
Hondadude is right. Smart.
Old 02-01-2007, 08:28 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">There shouldn't be any need for adjustments because the barometric pressure sensor is supposed to know the difference, and tell the ECU to wise up to the higher altitude.</TD></TR></TABLE>True, there's no adjustment. Air/fuel ratio & engine controls are all good.
But the lack of power is just life. Can't do anything about it (install a turbo?).
Old 02-01-2007, 08:32 AM
Honda4lyf's Avatar
Default Re: effects of altitude on acceleration? (JimBlake)
Doesn't the ecu adjust itself for this?
Old 02-01-2007, 02:48 PM
amckee's Avatar
Default Re: effects of altitude on acceleration? (Honda4lyf)
The MAP sensor will adjust the air/fuel mixture according to barrometric pressure, however, there is less oxygen at higher altitudes. The size of the throttle body is fixed, so less oxygen per gulp of air will mean less fuel mixed with it and, consequently, a little less power.
Old 02-01-2007, 04:33 PM
JimBlake's Avatar
Default Re: effects of altitude on acceleration? (amckee)
The percentage of oxygen in the air doesn't change much, but the overall amount of air is less. So the engine can't suck in as much air. Just like you can't suck in as much air when you breath.
So it's not just less oxygen, its also less nitrogen & everything else.
Old 02-01-2007, 05:50 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda4lyf &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't the ecu adjust itself for this?</TD></TR></TABLE>
when you got less air, you got less air, the ecu can do slight adjustment but ultimately it can't change the fact that it got less air
n20
Old 02-02-2007, 02:11 AM
YeuEmMaiMai's Avatar
use 85 octane fuel if they have it
nemesis25
11-14-2007 03:10 PM
renton
Honda Civic (2006 - 2015)
10
05-30-2007 03:51 PM
elpiar
06-30-2005 11:35 AM
civic777
10-12-2003 06:48 AM
rjcrxdohc16
09-25-2003 06:57 AM
Quick Reply: effects of altitude on acceleration?
