ECU will not reset...wat??
So I was diving like an idiot in my 1994 ex automatic on a hot day with the a/c on and 3 people in the car. CEL came on and the car would not rev past 4000 rpm. I just pulled the code and its a 22 (vtec). I pulled the Radio(back-up) fuse to reset the ecu. WITHOUT STARTING THE CAR it still throws a code 22. How is that possible. The ecu cannot check the VTEC system without the car running, right??
Re: ECU will not reset...wat?? (sivikvtec)
You are correct about the ECU not checking the pressure switch before the engine is running. How long did you have the fuse removed for? Try a minute or two. If that doesn't work try disconnecting your (-) battery terminal for a minute. If the backup fuse didn't do the trick this will for sure. It will also wipe out any of your radio presets so you will have to reprogram your stations.
Re: ECU will not reset...wat?? (GhostAccord)
I disconnected the (-) terminal on the battery for nearly an hour and its still there. any other ideas??
Ya got me. That should clear the codes.
Have you done any testing on your VTEC pressure switch? or tried replacing it to see if the code clears.
but how would it throw a code (yea its probably bad, definately is leaking oil in that area) WITHOUT THE ENGINE STARTED???!
I am so confused, maybe i'll take off the negative terminal and let the car sit for a few days lol.
Re: (Ross 2.0)
So even if that was the case, how could that happen without the engine even running? I'm going to mess with it today and see what I can figure out.
Re: (sivikvtec)
Well, i've messed with it some more with no success. I'm guessing the wiring or the pressure switch is messed up. So since this was a free car and i'm already going to have to drop $$$ on replacing the steering rack, I've got a plan.
gonna unplug and then bypass the switch
Re: (sivikvtec)
SO you bypassed the VTEC pressure switch and it got rid of your CEL. Doesn't that also mean that you no longer have the use of your VTEC pressure switch or is your pressure switch on all the time now? I was under the impression that without the pressure switch you wouldn't have VTEC. Anyone???
Re: (GhostAccord)
The pressure switch checks to make sure there is sufficient oil pressure. If oil pressure is low enough to where higher rpm could damage the engine, vtec does not engage. The switch appears to only be installed on OBDI USDM engines only. That bypass is for people using OBDI USDM ECU's and a JDM engine swap. So now, the ECU doesn't even "check the switch", its just a hard wired complete circuit. So now I have VTEC back and no CEL.
Modified by sivikvtec at 6:39 PM 8/18/2008
Re: (sivikvtec)
Ah, So now the ECU sees sufficient oil pressure all the time. See that's why I stay NonVTEC too many things to go wrong. So what happens if you really don't have sufficient oil pressure to close the pins in the rocker arms?
In a Junkyard near you.
Not so much. We have cars come in all the time with VTEC codes and the engines are just fine. They are just lazy and don't change the oil enough.
So if VTEC did engage it could use up the last bit of oil it had and starve the engine.
Just be sure you check the oil every few weeks.
Re: (Ross 2.0)
The oil level is fine. It obviously can't be that big of a deal if honda only found it necessary to put it on USDM cars.
