ECU question for an F20B!!!!! (HELP)
Old 08-22-2006, 02:46 PM
NO_FEAR_LWO's Avatar
Default ECU question for an F20B!!!!! (HELP)
hey just came here for some help.. just wondering on what to do.. just finished dropping an F20B motor into my civic coupe.. Now heres the question , which ecu do I stick with??? I have a p28 where I used an obd1 obd2 converter .. the ecu runs like *** maybe with better tunning I should get another program for the ecu. Since this nonsense occured should I stick with the stock OBD2 PCb 004 ecu that the F20B comes with.. please someone tell me the difference between both ecus because I want to get the max potential from this motor
Old 08-22-2006, 05:24 PM
xbn83's Avatar
Default Re: ECU question for an F20B!!!!! (NO_FEAR_LWO)
What map you run with P28? If you run with H22 base map you should be ok. I don't know what ECU F20B running, but I think you could use H22 ecu, but if I remember right all ECU from 97-01 equipped with immobilizer. I think the only choice is 96. Correct me if I'm wrong. By the way, you should post in Prelude forum as well. You might have more help there.
Luisb1982
05-18-2019 04:21 PM
lilrobie69
01-13-2013 09:36 AM
NO_FEAR_LWO
08-22-2006 04:10 PM
Quick Reply: ECU question for an F20B!!!!! (HELP)
