Conversion Harness For 94 Accord?
Re: Conversion Harness For 94 Accord?
just google search an OBD-1 to OBD-2 harness. But just so you know I believe there is more than just that to putting the H22a4 in the 94 accord than that. Wiring wise. Obviously the basic H22 stuff, but there is some extra stuff when converting.
GL.
GL.
Rywire $300+. They require you to supply your F22 engine harness and an H22 engine harness. If you don't have the H22 I guess they can sell you one.
Check it out yourself!
http://rywire.com/store/9097-accord-...47b9b124dffe9a
or you can make your own, very easy to do, and there is plenty of info here and all over the internet on how to do it
are you planning on running an obd2 or obd1 h22?
if you use a 94 and earlier h22a, you can use the stock accord harness and convert it ...i believe you just have to run extra wires for vtec oil pressure, vtec solenoid, and knock sensor. you might also have to extend a few wires..
save yourself a few hundred bucks.
i went from a stock 92 lx auto accord motor and ended up w/ a 94 h22a and also did a manual conversion. no conversion harness needed. not that hard to do at all.
soon2b
11-30-2004 12:40 PM
