ECM failure - can I swap & do I need to reprogram? - Honda-Tech
Old 12-07-2009, 12:39 PM   #1
gshock's Avatar
Default ECM failure - can I swap & do I need to reprogram?
I just had the CEL come on this morning. I had the codes checked, P1607 (ECM circuit failure) & P1259 (VTEC system malfunction). I'm guessing the P1259 comes from the ECM failing.
I've called around and a new ECM is about $825. I can get a used/salvage one for about $125. Shouldn't be too hard to swap. Just need to pull the center console. Do I need to reprogram it? I found one on eBay that should fit.
I know I need one for an AT, but I don't know if I can just pull one from an LX or EX and drop it in my SE.
gshock is offline   Reply With Quote
Old 12-07-2009, 02:21 PM   #2
New User
Default Re: ECM failure - can I swap & do I need to reprogram?
go with the used one,
u wont need to reprogram it...
just plug n the new/used one
4thgencb7tuner is offline   Reply With Quote
Old 12-07-2009, 02:46 PM   #3
He knows where you live!
TheMuffinMan's Avatar
With a 2000? You have a immobilizer if I'm not mistaken - which would require the ECU to be reprogrammed.
TheMuffinMan is offline   Reply With Quote
Old 12-07-2009, 06:06 PM   #4
gshock's Avatar
Quote:
Yeah, it does have an immobilizer so it will need to be reprogrammed. I'm just not sure how picky I have to be when finding a replacement. Can I pull one from an LX? EX? Etc?
Mine's a 4cyl, 2.3 VTEC ULEV, AT, w/AC, no California emissions. But I'm not sure if I can just pull one from any 2.3 VTEC with an AT. I'm hoping that I can, just go in and have it reprogrammed, and drop it in myself.
Old 12-07-2009, 06:23 PM   #5
GhostAccord's Avatar
You need to get an ECU for a 98-02 automatic F23A4, 2.3L VTEC ULEV. A regular 2.3L VTEC will not work properly with the ULEV sensors.
GhostAccord is offline   Reply With Quote
Old 12-07-2009, 06:38 PM   #6
gshock's Avatar
Quote:
Yup, I figured that would be the case, but I just wanted to make sure.
Thanks, Ghost.
Old 12-07-2009, 06:42 PM   #7
np
Old 12-10-2009, 09:44 AM   #8
gshock's Avatar
I got a new ecm for my car, exact replacement. I talked to the dealer, and they'll reprogram it for me for $100, but they said they need the car to do it. That doesn't make a lot of sense to me.
Anyone have a similar situation? How did they reprogram the ecm?
Old 12-10-2009, 09:48 AM   #9
I believe they need the VIN and can go by that.
Old 12-10-2009, 09:52 AM   #10
gshock's Avatar
OK, that makes sense. They probably code the VIN into the ECM. I'm sure it has something to do with making sure the car isn't stolen or something.
02 civic ecm swap Marquis Allen Honda Civic (2001 - 2005) 5 10-13-2016 06:26 AM
P1457 and bad ECM? BrettBaker Honda Accord (1990 - 2002) 21 09-16-2016 04:18 PM
02 civic eld power problem well i think i found out what i need to do to get it to always be puttin HondaCivic02EX Tech / Misc 0 11-26-2005 07:43 PM
PLease tell if anyone knows... About Stock ECM 98Preluder7 Honda Prelude 2 12-15-2004 09:23 PM
Need ECM help!!! kornaz Honda Motorcycles 5 05-07-2004 01:52 PM
Tags
1999, 99, accord, acura, code, ecm, ecu, honda, p1607, replace, reprogram, reprogrammed, reprogramming, reqiure, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
