dual filament tail lights question...
Old 08-25-2009, 05:03 AM
studlete's Avatar
Default dual filament tail lights question...
Okay so break lights don't come on when I hit the breaks. Every once in awhile they come on.
Now does this sound like bulbs (which I checked and are fine)?
Could it be a dual filament loose connection (burnt out)?
Or the break light switch?
****... could it be the ECU?
Help! Failed first inspection cause of this CCRRRAAAAAAAPPPPPPP!!!!!!
Old 08-25-2009, 05:13 AM
He knows where you live!
TheMuffinMan's Avatar
Default Re: dual filament tail lights question...
Brake light switch and the bulb would be my first two checks
Replace the bulbs as they're easy and cheap, it'll also rule out a bad/loose connector.
Old 08-25-2009, 08:07 AM
brages's Avatar
I would be thinking of problems that would affect both break lights, assuming both are affected.
Old 08-25-2009, 08:54 AM
differnc's Avatar
Indeed, which is why the switch would be my first choice, and the bulbs would be my last. Is the car equipped with the third light? If so, how's that behaving?
Old 08-25-2009, 08:56 AM
P_Adams's Avatar
If all brake lights are inop (including the high-mount window one), you've most likely a bad / maladjusted brake lamp switch mounted on the brake pedal brackets. If you've an automatic, this can also effect the Shift interlock release solenoid.
The intermittent part of your posting tells me that your fuse should pass muster.
P
Old 08-25-2009, 03:41 PM
studlete's Avatar
hmmm interesting. All lights break lights including the window one don't come on (sometimes they do sometimes they don't).
I broke the pin in my shifter and replaced it. then my diagnostics revealed a messed up shift control selonoid.
I replaced the selonoid and my TCU and now the trans runs like new. But prior to this the lights went out. (about 6 months ago)
so could the shifter be the culprit? (spelling?). YOu know ever sinc pep boys did my breaks this **** started happening. Thank god I started working on this my self and thank god for this website!
Old 08-25-2009, 06:28 PM
P_Adams's Avatar
Again...Brake Lamp Switch.
Most likely misadjusted or starting to fail.
P
Old 08-26-2009, 10:22 AM
bigmad72's Avatar
i agree brake light switch.
shdow8948
05-19-2011 08:53 AM
mkrieger500
Lighting
12-13-2010 03:58 AM
HondaKid_1
07-12-2008 08:16 PM
Quick Reply: dual filament tail lights question...
