Driverside automatic seatbelt stoped working !
Driverside automatic seatbelt stoped working ! 1990 Accord LX
I tried pulling it up to the soulder, it goes back when you open the door and stays there. It will not go to the shoulder when you turn the key on.
Modified by mikiedaddi at 10:48 AM 5/19/2008
Re: Driverside automatic seatbelt stoped working ! 1990 Accord LX (mikiedaddi)
Head to the local Honda dealership;
the seat belt is unsafe and therefore covered under Warranty.
If the service writer gives ya any lip about charging you, call American Honda Customer Care 1-800-999-1009
Re: Driverside automatic seatbelt stoped working ! 1990 Accord LX (hondadude)
There is lifetime warranty on seatbelts? I didnt know that. His car must be 1990 or less to have the automatic seatbelt, correct?
New User
I have a 91 honda accord and tonight first my passenger one stopped working, then it started to work and my drivers side stopped, now neither of them work. So if I go to a honda dealership they have to replace them. This is really a crappy time, i have no money at all.
Yes, I have had the dealer replace many of these belts being a car dealer myself and purchasing lots of these vehicles with bad seat belts. I believe it was late 1990 or early 1991 that there was a major lawsuit because a person was decapitated by one of these types of belts. They probably didn't use the lap belt along with it.
New User
The belts are covered but the motor isn't, i called that 1-800 number to american honda so the only thing covered is where the belt clips in.
He knows where you live!
If there is neglect involved on the owner's part (scissors/cuts/ripping) then it's not covered by the warranty.
i agree w/ muffinman
other manufacturers of automotive belts are also covered for the lifetime of the owner/vehicle i.e. nissan,
heck, that's why newer vehicles stopped using motorized passive seatbelts and went back to regular do-it-yourself belts
I hate to beat a dead horse, but I just wanted to hear it one more time. I also have a 90 Honda Accord with the Driverside automatic seatbelt that stopped working. It just seems to good to be true that we can take our cars to Honda and have this repaired under warranty.
As to why they don't use the motorized belts anymore, the main reason is the feds pulled their heads out of their ***** and stopped requiring it. Also, they are more expensive and NOBODY likes them.
Just another example of the fed. government being idiots with regulations.
Now let's see if i have this right.
I can bring my 19 year old accord with a passenger side belt that runs back and forth on it's own, to the dealer and they'll fix it on their dime?
It acts like a bad door switch, but, the dash door open indicator light works perfectly which tells me the switch works.
And if after the 20th time of reading it you can't determine what they'll do here it is again.
If it is a safety issue that is NOT related to abuse then it is covered for the usable lifetime of the car. So if while driving it moves away from your body and then towards, just randomly back and forth. And it is a seatbelt issue NOT a door issue then it is covered. You can easily call American Honda.
I really wish I could find any other answer to this question than "It's covered by warranty!" It's not. Maybe it is supposed to be but I've called two dealerships and American Honda and both of them have told me that this issue is NOT covered by the warranty. I wish it was. But since it's not, it would be SUPREMELY helpful if someone actually had the information on how to fix it.
2) You do not mention what your problem is at all
3) You do not mention what caused the problem
Also the dealership and Honda of America may have found you negligent in the damage - therefore not required to cover it. You also have a 21 year old vehicle with however many thousands of miles which Honda may now consider outside of the lifetime of the car. In addition to that you make no mention of any modifications done to the vehicle - if it was heavily modified and you messed with the seat belts (removed them or whatever) they may also deny it because of tampering. There are a lot of factors.
https://honda-tech.com/forums/honda-prelude-4/honda-lifetime-seat-belt-limited-warranty-2201139/
Has some success stories about it.
Also this document covers the actual statement from Honda.....
http://techinfo.honda.com/rjanisis/p...303O00300A.pdf
Originally Posted by that document
Seat Belt Limited Warranty - a seat belt that fails to function properly is covered for the useful life of the vehicle
Our District Rep said something to the effect of; Automatic seatbelts are covered. If a bad position switch causes the seatbelt to not function properly, it is covered. If the failure is caused by the consumer, it is not covered.
We replace control units that fail. A faulty control unit keeps the seatbelt from functioning properly. Etc.
As far as useful life goes, we haven't encountered that yet. And, that is considering we've seen vehicles with nearly half a million miles on them.
FAQ : Does anyone know where to find the actual warranty PDF 91 Honda Accord EX???????
Here it is. I'm going to flash this next time i go for to a Honda dealership. http://mustardcat.brinkster.net/p3g/...rantybelts.pdf courtesy of Nicefeet
well, that sucks big time!
good thing in the 240sx arena, a guy actually went through h377 and back to validate that they were still covered in the "LIFETIME WARRANTY"
http://forums.nicoclub.com/broken-se...e-t405244.html
do you know how to do the manual over-ride? in case you checked the fuse first and it was OK?
I have a similar torx head tool in my glovebox still for my 89 nissan 240sx ~LoL
Owner's manual say that 'if the seat belt motor" does not come on after changing the fuses...then move the seat belt mechanism manually to the back and 'usefull' position.
My owners manual says there is a 'plastic plug' on the 'b' pillar at the bottom. You have to pry that 'plug' off and insert a tool, that came in my 'flat tire' tool box to manually pull the sealt belt mechanism to the back position.
The tool look like a 'torx' head screw driver with a 'push' on 'wheel' so you can wheel back the mechanism. I have seen both of these items in my 'flat tire' tool bag that came with the car.
Got a call from Jeff a "big dog" for Honda out in Calli. and he told me that honda does not cover the mechanical parts of the seat belt after 20 years but as a courtesy they would be willing to cover a percent of the $1000 dollars i was quoted to get it fixed at Auto Park Honda in N.C. When i asked why he would only give me a percent because the Honda service bulletin clearly states that the "bet/retractor mechanism or buckle" are covered under Lifetime Warranty(defect code L32/Labor op#854175) he said and i quote "If you continue to use that terminology i will have to part ways with you" in other words hang up. IS THAT HOW YOU TREAT CUSTOMERS. He refused to talk about the service bulletin(#92-012). So I am now waiting on a case manager to get back to me after they consult with Auto Park Honda about what percent will be covered. If this guy Jeff is going to help me at all I'm sure he will make it as minimal as possible. I think once i learn the percent they are willing to cover i am going to send all this to the local papers. A Lifetime warranty is a Lifetime warranty Jeff whether or not u want to talk about it. And remember Jeff a Honda employee was the one that showed me this Bulletin and printed it for me. So it is in your systems and you must see it too. SO IT DOES EXIST!!!!!
