drain water from block
Old 11-26-2012, 11:12 AM
sgull's Avatar
Default drain water from block
My 92 Honda Accord will need to sit in freezing temperatures for over a week until I can have the opportunity to have some repairs made to get it running again (distributor problem, will not start/run). Right now it has no coolant in the engine, only straight water. I'm concerned about the water in the block freezing and need to know if there's possibly a way to drain it all out. Hopefully there is an accessible plug on the block I can unscrew? Any help/comments appreciated. Thanks
Old 11-26-2012, 05:16 PM
Lost Again's Avatar
Default Re: drain water from block
Look on the back side of the engine - engine to firewall - to the left drivers side of the oil filter for a drain bolt.
Old 11-26-2012, 09:54 PM
361 accord's Avatar
learn something new evey day
what i did to flush all the distalled water and get perfect fill of premixed honda blue was to turn the heater full hot. pull off the lower heater hose at the valve and blow air into the radiator fill with a leaf blower
go ahead and laugh, but a shitload of water came out.
at least then you could fill it with cheap premix if you wanted to.
idk if you would wanna leave it out empty because any traces of water can still freeze, it just depends on how paranoid you are i guess
(since you cant run the motor to mix straight water w/ straight coolant)
hope this helps!
Old 11-27-2012, 07:01 AM
sgull's Avatar
Great. Thank you for that description and diagram.
SPOOLINmatt
03-12-2011 11:57 AM
tjowers
12-14-2009 01:01 PM
st_rage
13
12-25-2008 09:56 AM
mikestypeRR
11-17-2005 01:11 PM
SUNBURST
14
01-20-2004 09:53 PM
Quick Reply: drain water from block
