door sensor problem
door sensor problem
on my 93 honda accord the door sensor on the pass. door doesn't recognize that the door is closed so i switched the sensor from the driver door and same thing happened. im getting sick of the light on my dash and i have to turn off the celing light because it stays lit. any suggestion on whats the problem???
Re: door sensor problem
Sounds like you have a problem. I am not at work and don't have ETM's at home. I am thinking there may be a latch switch in the door latch. That would explain why your door switch swap had no positive results.
wraydp
29
05-13-2017 03:44 AM
