Dome light not working - Honda-Tech
Old 03-04-2012, 06:54 PM   #1
19Accord97's Avatar
Default Dome light not working
Any ideas why the dome light will not come on when I open the door? It works when I move the switch to the ON position but will not turn on when a door is opened when the switch is in the middle position. Also, the courtesy light on the rear passenger door will not work either.
19Accord97 is offline   Reply With Quote
Old 03-07-2012, 11:12 AM   #2
Default Re: Dome light not working
Does the dash board display light up for each of the doors when they are opened? If they all work, then the door switches are good. Check the bulb for that rear passenger door.
You could try checking if current is getting to the switch when the door is open, with a volt meter.
professorman is offline   Reply With Quote
Old 03-07-2012, 05:30 PM   #3
Have you tried the other doors to see if they trigger it? Say if it is just the driver's door chances are the switch in the jam is bad.
motegicivic is offline   Reply With Quote
Old 03-07-2012, 06:59 PM   #4
ricebike's Avatar
you'll just have to open the cover and inspect the bulb! if it's good or you have no idea, try this:
switch the bulbs withe the rear driver side courtesy light & see if that bulb lights up when you open that rear passenger door again... to rule out a bulb problem.
ricebike is offline   Reply With Quote
Old 03-07-2012, 07:33 PM   #5
19Accord97's Avatar
I've already swapped new bulbs and even led's for both the dome and the door.
The dome light will not come on no matter what door is open. The dash will let me know if a door is open but I dont think it will register/can tell if the rear passenger door is open. I will have to double check that.
Old 03-09-2012, 05:50 PM   #6
By chance would you have an aftermarket alarm system?
http://honda-tech.com/showthread.php...ght=dome+light
Worth checking.....
Lost Again is offline   Reply With Quote
Dome light problem hon0405 Honda Civic / Del Sol (1992 - 2000) 8 12-07-2016 02:29 PM
2002 Accord - Dome light not working when on "Door" setting pk_man Honda Accord (1990 - 2002) 2 12-06-2013 07:57 PM
97 Civic Viper 5704 genner Audio / Security / Video 5 02-19-2013 09:05 PM
map light wiring problems, need help MrLeWayne Audio / Security / Video 7 11-21-2010 01:46 PM
searched eg dome light problem dognutz Tech / Misc 7 08-11-2005 05:26 AM
Tags
2012, 97, accord, cabin, civic, dome, door, hoda, honda, light, open, turn, wont, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
