low rpms, engine shaking below 1000 rpm
Old 10-14-2005, 11:13 PM
kyosuke714's Avatar
Default low rpms, engine shaking below 1000 rpm
94 accord lx A/T 168000k
At start ups, everything seems to be fine until it gets warm. My engine starts to shake when it goes below 1000 rpm and drops to 500 rpm at stand still. When i reverse out of my drive way...it feels like its gonna die. When I check the air coming out of the exhaust...it feels like its sputtering...like those old a$$ cars...it ain't smooth...is that normal? Things I've tried so far: clean egr, clean iacv, seafoam. replaced FITV. I changed my plugs, plug wires, cap, rotors a couple months ago when I still had this problem...didn't help. I'm changing them again tomorrow. I'm also gonna be doing my valve adjustment and my timing tomorrow hoping it will help. i think my cables are fine. Can anything else be causing this problem?
Old 10-15-2005, 04:07 AM
AcclipseH23's Avatar
Default Re: low rpms, engine shaking below 1000 rpm (kyosuke714)
Does it feel down on power while you are driving? It may be ignition related.
Old 10-15-2005, 05:17 AM
m0t0rhead's Avatar
Is your Check Engine Light on ? If so, pull the codes and post them up.
Old 10-15-2005, 07:20 AM
P_Adams's Avatar
Sounds like you may have a vacume leak in the vicinity of the intake manifold causing one or more cylinders to run lean at idle, a dirty injector would show like this as well.
P
Old 10-15-2005, 07:56 AM
SuperSlow's Avatar
check your throttle cable, vacuum hoses, plugs, then clean out your egr, then check your injectors.
This is the order I would check from least expensive to most.
Rotting Prelude
08-22-2017 12:32 AM
rice is nice
08-25-2009 07:02 AM
JDMkidGSR
08-01-2006 02:20 PM
wstef
10-20-2004 01:30 AM
h23 milano red
04-09-2004 04:49 PM
Quick Reply: low rpms, engine shaking below 1000 rpm
