Distributor Install
Old 07-31-2007, 06:29 PM
bacid's Avatar
Default Distributor Install
I'm going through the distributor install and see taht I have to put the #1 piston in TDC, how do I do this?
Old 08-01-2007, 09:42 AM
professorman's Avatar
Default Re: Distributor Install (bacid)
Is that the distributed cap? Just label the wires with some masking tape and remove the cap and re-install it. I havent done a entire distributer before, so I dont know. Read the manual?
Old 08-01-2007, 10:09 AM
H-T Order of Merit
TouringAccord's Avatar
if you have a manual it should be described in there.
But if not, see my timing belt write-up thats linked in the FAQ. I describe how to do it in there.
Old 08-01-2007, 11:01 AM
bacid's Avatar
i have the factory honda manual but i wasn't about to find how to turn to TDC.. i assume this is something basic which all mechanics know!
i'll check the FAQ, thanks!
Old 08-01-2007, 11:26 AM
H-T Order of Merit
Default Re: (bacid)
if you have the factory manual it's in there.
look for the sections that describe how to do valve adjustments or the timing belt section, it should be in one of those two sections.
Old 08-01-2007, 06:14 PM
bacid's Avatar
will do, MUCH THANKS!
Old 08-02-2007, 04:55 AM
H-T Order of Merit
Default Re: (bacid)
yep, np
dlowdog
12-30-2005 11:07 AM
LudeChild
01-21-2005 04:38 PM
bad-monkey
12-05-2004 05:22 AM
rayscar
10-21-2004 01:36 PM
Quick Reply: Distributor Install
