Disabling the automatic seatbelts of a 91 accord
Old 01-24-2015, 08:42 PM
nstock's Avatar
Default Disabling the automatic seatbelts of a 91 accord
Does anyone happen to have thoughts on the best way to disable the automatic seatbelt feature on a 91 Accord (leaving them in the all-the-way-back position)? I was hoping there was simply a circuit breaker I could pull to do so, but it's unclear which one that would be, and what else would be disabled by doing so.
Thanks in advance for any suggestions!
Old 01-24-2015, 09:11 PM
holmesnmanny's Avatar
Pull the relays in the engine bay fuse box.
Old 01-25-2015, 12:50 PM
nstock's Avatar
Default Re: Disabling the automatic seatbelts of a 91 accord
After a little more research, I found out that the fuses labeled "R passive motor" and "L passive motor" refer the power seatbelts, so that should do it!
Old 01-26-2015, 03:00 PM
kevinhughes13's Avatar
I went through this last year and here's what I found. The fuses to the automatic seat belts at-least in my 90 were linked to other electrical components so if you look under your passenger seat you'll see a black box turn your key on get them in the back position and unplug that and you should be good to go.
Old 01-26-2015, 09:47 PM
nstock's Avatar
Great, thanks for the suggestion. I will go with that instead - sounds less likely to impact other parts of the car.
Old 01-27-2015, 07:38 AM
Tachi's Avatar
I remember going through something similar on my 90 rx7, can CD seatbelts be retrofitted into a CB chassis?
bgoetz
09-04-2007 08:34 PM
EGhatch33
01-30-2007 07:42 PM
Dave R
07-05-2003 05:54 AM
patastinky
12-03-2002 12:09 AM
Quick Reply: Disabling the automatic seatbelts of a 91 accord
