Where is my idle control valve?
Old 04-18-2010, 03:26 AM
Belarus's Avatar
Default Where is my idle control valve?
Hey guys, could anyone tell me where my idle control valve is in these pictures? I'd like to clean it. Thanks.
Old 04-18-2010, 08:45 AM
GhostAccord's Avatar
Default Re: Where is my idle control valve?
The rotary air control valve on your ULEV should be on the back of the intake plenum just to the right of the throttle body. It's Between the plenum and firewall, you can't see it in ether of the pictures you have posted.
It is located on the back, under the hose indicated by the red arrow.
Old 04-19-2010, 03:51 AM
Belarus's Avatar
Thanks a lot! So it's a pretty hardy-accessible location. I guess I will put the cleaning off a little )
Old 04-19-2010, 06:21 AM
skracer13's Avatar
Pull off your throttlebody for easy access. (Four 12mm bolts)
Forgot to mention, Where GhostAccord pointed out (red arrow) its a little bit lower and to the right. If you still can't find it, let me know and I can put up another pix for you.
Old 04-19-2010, 04:00 PM
quickster's Avatar
might as well change your fuel filter while you are in the area.
Old 05-01-2010, 05:31 AM
Belarus's Avatar
Actually, my fuel filter is in the fuel tank as far as I know
jojo23
Honda CR-V & Element
09-21-2017 05:29 PM
h22vt
04-20-2006 09:34 AM
shabasoft
12-22-2004 04:05 PM
ZeroGSR
09-10-2003 03:42 PM
Quick Reply: Where is my idle control valve?
