Fuel + Spark + Compression = Nothing in Cyl #2?
Old 03-08-2009, 11:32 AM
0x5359-0055
213374U's Avatar
Default Fuel + Spark + Compression = Nothing in Cyl #2?
Had to start a new thread for this issue. A little backstory on the problem can be found here ---> https://honda-tech.com/forums/honda-accord-1990-2002-2/injector-issue-2518515/
READ THE ABOVE BEFORE YOU READ THIS POST!!!
So this morning I go out and re-adjust the valve lash. Everything set to specs. Go to fire it up.... still missing Cylinder 2. Do a compression test.... 152 in #4 and 160 in the rest.
WTF!?!? Spark + Fuel + Compression = A working cylinder... right!?!
ANY insight at all would be awesome. P_Adams, shed some light for me
Old 03-08-2009, 12:42 PM
0x5359-0055
213374U's Avatar
Default Re: Fuel + Spark + Compression = Nothing in Cyl #2?
Would a clogged/dirty fuel filter cause a single cylinder to misfire? Only other thing I can think might be off is my valve adjustment, first attempt at it, but I checked, re-checked, then checked again all 16 valves.
ECU maybe?
Old 03-09-2009, 02:24 AM
jwicecold's Avatar
ECU maybe?
Maybe valve adjustment might affect it, but how is the rod/ piston and rings in that cylinder?? Any signs of ware in that cylinder around the edges??
Old 03-09-2009, 05:58 AM
In a Junkyard near you.
Ross 2.0's Avatar
Have you tested the fuel injector to make sure it's really opening? Have an aftermarket alarm with fuel cut?
Old 03-09-2009, 06:26 PM
0x5359-0055
213374U's Avatar
Thanks for the insight fellas. But I was out playing around with anything I could think of and moved some plug wires around. #1 Cylinder stopped firing and #2 was fine. Set of plug wires later and she's running like new. The old problem of stuttering before VTEC has disappeared as well, that was what originally led me to believe it was a fuel issue. I was seriously relieved to find that it was nothing major.
Old 03-10-2009, 06:22 AM
jwicecold's Avatar
That was gonna be one of my next suggestions!! gotta luv those easy fixes, even if it does take a min to figure it exactly what it is!! glad its working for ya.
Jake Pierson
11-24-2018 07:53 PM
crix351c
10
02-25-2006 06:28 PM
7808
02-20-2006 09:04 PM
street dreams
11-21-2004 04:48 PM
Quick Reply: Fuel + Spark + Compression = Nothing in Cyl #2?
