F20B Swap
F20B Swap
hello to all i currently have a f22b1 sohc vtec in my 1995 accord coupe and i suddenly have the urge to do a F20b swap , sadly though ive never done any motor swaps but have wanted to learn and start doing such work with hondas , anyone have any tips or any kind of advice thanks in advance , or if you could let me know what all im going to have to change and what i should change it to let me know also its a automatic accord =( would like to swap it to a 5 speed but dont know how much trouble it would be
Re: F20B Swap
For information regarding your "general" question look in the FAQ`s section at the top of the Accord forum.
The is FAQs on swaps, Just about everything you need to know. If you have specific questions it would be better.
Re: F20B Swap
As it was stated, there is tons of information regarding this particular swap, and it being almost identical to an H22, you will find a lot of information. One rule of thought I have gone by is if you have to ask, it isn't for you. But everyone must start out one way or another, I guess. Long story short, you need the engine, mounts, figure out the ecu (obd1 or 2, I have heard that if you use obd1 prelude injectors, you can just run the P13). Being that the F20b only have one slot on the crank pully, you wont be able to run powersteering, unless it is possible to use an H22 pully. That being said, do your homework, and good luck.
