D4 Flashing on 96 Accord - Honda-Tech
Old 05-22-2011, 10:32 AM   #1
Chmura's Avatar
Default D4 Flashing on 96 Accord | How do I jump the service connector?
I've researched the subject before posting and there are many different answers I found.
The D4 just started flashing on my way home this morning. Car doesn't want to go to second gear, in first it goes fine then once it wants to go to second the speed just drops.
I think the tranny might have reached its time, but it may be something else.
Found a post about the paper clip method along with the image below, but none of the posts ever mentioned how to actually do this. Will it even work on my 96?
I made a thread about PO301 PO302 PO303 error codes a few days ago, could this be linked to that?
Chmura is offline   Reply With Quote
Old 05-22-2011, 06:40 PM   #2
Chmura's Avatar
Default Re: D4 Flashing on 96 Accord
anyone?
Old 05-23-2011, 01:20 PM   #3
Chmura's Avatar
Took the car out for a 5min drive today. D4 light wasn't flashing, yesterday it was flashing when the car was overheating.
So can anyone help out with the service connector?
Old 05-23-2011, 02:42 PM   #4
Jmb106jr's Avatar
I believe on the 96's there is the blue connector under the glove box on the passenger side. pull the connector w/ 2 wires out, and jump it w/ a paper clip w/ the key to the on position, you will be able to pull the codes watch the D4 light for flashes. Or you can get an OBD2 reader and pull the codes. The port is located behind the ashtray.
Jmb106jr is offline   Reply With Quote
Old 05-23-2011, 10:18 PM   #5
Chmura's Avatar
Many thanks man!! Will check it first thing in the morning
Old 05-25-2011, 08:21 PM   #6
ok bud i just fixed the same problem on my 97 do the paper clip method i got 7 blinks looked at my solenoid like the code said well sure enough it was disconnected urs might be different but look where the code tells ya to my mechanic made me waste 150$ on ecus b4 i did the paper clip
UgandaHonda is offline   Reply With Quote
switching ecu's p28 to Po7 shredderkid322 Engine Management and Tuning 0 04-06-2011 06:43 AM
2003 Honda Pilot error code PO172 grooner Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 2 11-21-2010 07:06 AM
h23a swap question zenon8890 Honda Civic / Del Sol (1992 - 2000) 3 09-02-2009 03:16 PM
JDM D15B CAM vs D16Z6 CAM - INTERESTING INFO b.serious All Motor / Naturally Aspirated 15 11-15-2008 03:32 PM
FS: STR Diffuser-NEW in package! 2 piece-Bling Bling, PO7 ECU SOUNDEFFECTS For Sale 3 08-19-2006 10:05 PM
Tags
1996, 4d, 96, accord, acord, blinking, blinks, cope, d4, drive, flashing, honda, jump, light, mpg
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
