cylinder 3 and 4 not fireing? help.
So I just did a straight swap f23a1 to f23a1 (obd2) and when I got it started which is difficult to do and it will not idle you have to hold it at about 2000-2500 rpm to keep it going. Cylinders 3 and 4 are not firing. They both have spark power to the injectors and 210psi of compression. Any ideas as to what could be causing this? Thanks.
Re: (Civic_07)
thats the only thing i havent check is to see if the injectors are actually firing, but what are the odds that 2 cylinders aren't sprayin.
any other possibilities?
jdmek2277
10
11-18-2007 04:34 AM
