F23A1 w/ H22 head
Old 06-19-2010, 12:10 AM
cuba11's Avatar
Default F23A1 w/ H22 head
I just bought ta H22 head and i was wondering if i need anything else to make the G series swap?? help please
Old 06-19-2010, 01:42 AM
jwicecold's Avatar
Default Re: F23A1 w/ H22 head
Let me know how that goes. I was gonna do the same thing to my f22 vtec block. Heard its a good combo. Wish I knew something bout it to help ya out..
Old 06-19-2010, 07:58 AM
AFAccord's Avatar
The head is only the beginning. What is your goal?
Old 06-19-2010, 08:19 AM
92civlude's Avatar
Piratemcfred has a thread on this swap in the prelude side.. There are also a couple more. Its more than just a "head swap". You must have a hybrid water pump.(H pulley on an F23 water pump body. You must also splice the water transfer tube. ( f23 tube into the block, H22 tube bolted to the manifold.) The front oil drain holes on the head must be blocked off. A machine shop did mine. They used little freeze plugs. If you run the F23 pistons, youll have only 8.8 comp ratio. I used K20a3 flat top pistons for about 10.5 comp ratio. There is also a nice writeup on this swap on HONDATUNING magazine. Just google G23 VTEC. Have fun!
Old 06-19-2010, 11:49 AM
nus_dogg's Avatar
I think you need to tap & plug up two oil passage hole on the H22 head and F23 water pump with H22 water pump gear. I'm sure there's more to it than this.
Old 06-21-2010, 04:21 PM
cuba11's Avatar
thnx a lot guys
94accordhswaped
10-12-2012 02:38 PM
honda4674
04-29-2006 01:31 PM
ArMaNiXcHaNgE863
01-19-2006 03:59 PM
Y2A
11-23-2003 09:05 PM
Quick Reply: F23A1 w/ H22 head
