Cruise control help: 94-97 accord
My CC has not worked since I bought the car, Its a 94EX MT.
I've replaced the actual unit, the ecu thing, and the button on the steering wheel.
The light comes on the dash button, but not on in the cluster when i press the button the the wheel. My speedo and odo work fine. I've searched everywhere...ANYONE??
Re: Cruise control help: 94-97 accord
Remember that the cruise control releases when the brakes are applied and if it either has an open (in the switch) or the connector's damaged - the cruise will not engage.
P
remember the clutch switch and brake light switch are a safety feature so if you depress the clutch or bake it will cancel the cruise until reset.
well, one problem down, it didn't have the clip in it, so i thought for SURE that was the problem right!??!...... WRONG, stupid thing still wont light up on dash(work)...any other ideas?
But after looking around i noticed the CC cable that gets hooked up on a plastic mount right on the throttle body came off. Just like a brake cable on a bike, there's a metal stud at the end, just clip that back onto the CC mounting piece thing and see if that works.
my brake switch broke on mine and i glued two pennies on the brake pedal and the brake light went out but my cruise did not work. so i glued one more and now it works.
Hate to revive an old thread, but what was the remedy after the junkyard visit?
I noticed this on my floormat of the car. Took a look under and I'm sure it use to rest on the cruise control switch.
check out the thread on brake lights that stay on when the car is off. I just had that happen and made a temp fix..now cruise control is not working. I've already ordered the plastic part just like the one you have a pic of.
1995 accord LX 347000 miles and still going strong. Original motor new radiator, new rad fan, all new front suspension, and a few other parts.
rickashay
04-01-2009 11:52 PM
schillage
02-26-2008 03:32 PM
A Tribe Called Honda
02-28-2007 02:53 PM
