Crankshaft bolt removal? - Honda-Tech
Old 03-09-2011, 08:27 AM   #1
Default Crankshaft bolt removal?
Hey folks
I have a 96 Accord Aerodeck Auto which needs the water pump replaced.
Have managed to get as far as trying to remove the flywheel but am unable to budge the bolt!
We have a tool to hold the flywheel and have tried using large bars on the end of the socket but can't move the bolt. Any ideas?
We have been trying to turn the bolt Anti clockwise.... is this correct?
thanks
romikbal is offline   Reply With Quote
Old 03-09-2011, 10:03 AM   #2
Jmb106jr's Avatar
Default Re: Crankshaft bolt removal?
Counter clockwise is the direction to remove bolt, you are correct. I have heard of people have luck removing bolt by heating it up w/ propane torch,ect, then hitting it w/ a impact gun. Good luck to you.
Jmb106jr is offline   Reply With Quote
Old 03-09-2011, 10:33 AM   #3
InvaderTrax's Avatar
Still haven't had issues using my big impact. You can always search the starter trick
InvaderTrax is offline   Reply With Quote
Old 03-09-2011, 10:44 AM   #4
djkurious's Avatar
djkurious is offline   Reply With Quote
Old 03-09-2011, 11:42 AM   #5
ek9civichb's Avatar
x2 step 10
ek9civichb is offline   Reply With Quote
Old 03-09-2011, 12:01 PM   #6
nus_dogg's Avatar
^^ x3!
And my nice impact gun has not failed on me yet when it comes to a Honda Crank Pulley bolt(Knock on Wood).
nus_dogg is online now   Reply With Quote
Old 03-09-2011, 12:43 PM   #7
djkurious's Avatar
Quote:
I definitely would not use this.
Old 03-09-2011, 12:51 PM   #8
MoguMagic's Avatar
Screw driver in the flywheel but you seem to have that covered, Large as you can breaker bar with an extension held up with jackstand/wood/whatever to not bend the extension as you turn it. Tighten it then try untighten. Always works after few min. Bounce, Jump. Hang on the bar listening to some sort of dance music. Just get it down and watch out if your under it when it goes.
MoguMagic is offline   Reply With Quote
Old 03-09-2011, 01:10 PM   #9
Thanks everyone!
Will persevere! Great Job with the write up Touring Accord!
Old 03-10-2011, 06:32 AM   #10
H-T Order of Merit
TouringAccord's Avatar
Quote:
Thanks
TouringAccord is offline   Reply With Quote
Old 03-10-2011, 06:33 PM   #11
MM Gruppe B
MAD_MIKE's Avatar
On the F and H engines this will tighten the bolt, not loosen it.
I used a jack stand under the extension as my fat ~230lb *** tried breaking the bolt free by diving board bouncing on it.
MAD_MIKE is offline   Reply With Quote
Arp Flywheel bolts vs Stock flywheel bolt angrysmileyface Honda Civic / Del Sol (1992 - 2000) 5 09-14-2014 06:09 AM
removing flywheel bolts without flywheel spinning JDMInspired Honda Civic (2001 - 2005) 3 03-17-2008 09:57 AM
Can i reuse flywheel bolts? RedEj8 Honda Civic / Del Sol (1992 - 2000) 15 06-06-2005 06:28 AM
Flywheel tool STS_Underdog Honda CRX / EF Civic (1988 - 1991) 5 08-02-2004 03:03 PM
Removing Clutch and flywheel civcexcoupeblack Acura Integra 6 03-19-2003 10:22 PM
Tags
2005, 99, accord, balancer, bolt, crank, crankshaft, h22, harmonic, honda, jdm, removal, removing, screw, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
