crank question
Old 11-05-2008, 03:01 PM
cjmurillo's Avatar
Default crank question
will an f23 crank fit into an f22 block
Old 11-05-2008, 04:50 PM
P_Adams's Avatar
Default Re: crank question (cjmurillo)
No.
Here's why
F22Bx
Main Journal Diameter: 50.0mm
Rod Journal Diameter: 48.0mm
F23
Main Journal Diameter: 55.0mm
Rod Journal Diameter: 45.0mm
You could grind down the main Journals and build up the Rod Journals, but that still leaves unresolved Cylinder spacing. The Main Journals may not line up Crank to Block
P
Z0831xiz
04-26-2015 03:56 PM
JSPECHB
12-21-2004 01:17 PM
Nextelbuddy
06-23-2003 02:23 PM
S13 slide
12-02-2002 05:54 PM
canuck-mx6
06-03-2002 04:38 PM
Quick Reply: crank question
