Cooling and Radiator Fans not coming on even with A/C switch to ON
Old 06-20-2011, 07:15 AM
pab59y's Avatar
Default Cooling and Radiator Fans not coming on even with A/C switch to ON
I have a 1992 accord, both of my fans will not come on even with the a/c switch to on. I jumpered the fans throught the condenser relay connector ylk/blk and red, and both fans will come on when I turn the A/C switch on. So, I thinnk the fan motors are okay. I checked the no. 2 fuse and it is good. I am lost as to what is wrong?
Old 06-20-2011, 05:38 PM
poorman212's Avatar
Default Re: Cooling and Radiator Fans not coming on even with A/C switch to ON
Wow, I saw this same thread somewhere else....let's start with the easy things. Jump thermo/switch a on the t-stat, key on, do BOTH fans run?
Does the ac work?
Old 06-20-2011, 06:30 PM
pab59y's Avatar
hi poorman212 ...
it is the same question on different forums. so, how do I jumped the thermo/switch A? Do I disconnect the switch and jumped the connector? I am still not sure where switch A is located, but assume it is a 2-p connector, correct?
Thanks!
Old 06-20-2011, 06:32 PM
pab59y's Avatar
also, if both fans run. does it mean that the switch is bad?
Old 08-01-2011, 11:51 PM
T Wgproductions's Avatar
i posted in a diff forum a similar problem.. still waiting ona response.. Cause my fans won't come on with the ac on or off .. im really confused.. im about to go jump that thermo switch right now to see what happens
update jumped therm switch NOTHING
Old 08-02-2011, 09:52 AM
RichardWLandis's Avatar
my ac fan does not come on. ac does not work. i unplugged the connector at the fan and ran a hot wire and ground wire to 2 pin connector, still will not come on. 1994 honda accord
Old 08-02-2011, 01:35 PM
holmesnmanny's Avatar
That obviously means the fan motor itself is not working. Pick up a new fan motor from the junkyard.
09-03-2006 03:02 PM
trrbl1bmx
16
08-02-2006 11:51 AM
NosCivic01
05-17-2006 11:55 AM
95hondaprelude
03-20-2006 10:13 PM
Quick Reply: Cooling and Radiator Fans not coming on even with A/C switch to ON
