Cooling fan not turning on when engine gets to operating temp - Honda-Tech
Old 05-05-2013, 06:36 AM   #1
Default Cooling fan not turning on when engine gets to operating temp
Hi All,
noticed the temp guage getting about 3/4 the way up the other day. If i crank the heater it helps bring the temp down.
I turn on the AC and both fans will come on, when I shut it down the cooling fan will run for a while like it is supposed to.
So the cooling fan isn't turning on when it gets to operating temp.
I jumped the connector on the Thermo A switch and the fan turned on so I replaced the Thermo A switch but it didn't help.
Faulty new Thermo A switch perhaps?
thanks!
torino420 is offline   Reply With Quote
Old 05-05-2013, 09:07 AM   #2
Default Re: Cooling fan not turning on when engine gets to operating temp
replacing thermostat next, upper hose is hot and lower is cold when it gets to operating temp.
Makes sense as to why the fan doesn't kick on because it doesn't detect the correct temp because the thermostat is stuck so it's still cool there.
1996 Honda Accord coolant boiling in radiator rriznyk Honda Accord (1990 - 2002) 1 06-19-2014 03:42 AM
Heating up Nerdskateful Honda CRX / EF Civic (1988 - 1991) 9 06-03-2014 04:21 PM
94 Accord "Normal" fan operation accord4 Honda Accord (1990 - 2002) 2 01-21-2010 06:04 AM
I know.. another overheating issue, but read though! Memnoch Honda Civic / Del Sol (1992 - 2000) 8 07-11-2008 08:47 PM
3rd Gen Prelude overheating, need a second opinion. ryanstev Tech / Misc 1 03-04-2004 11:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
