96 accord cyl 1 miss, cant figure it out.
f22b1 only code it throws is cyl 1 miss. has brand new cap rotor and wires, ngk's about 4 months old.swapped injector and plug from #1 to #3 and still same thing, cyl 1 miss. tried another ecu today and still the same problem. it only misses when under a load, going up a hill even a small one at light throttle and it starts to sound like a subaru. any ideas?
Re: 96 accord cyl 1 miss, cant figure it out.
i changed the egr valve a few months ago and as far as i could see the port wasnt clogged. what makes you think thats the problem?
ill check that out in the morning, dont understand why that would only make cyl 1 miss tho and why it dosnt thow and egr code
Fortunately on your car it's easy to clean out the ports. You need to research what the egr system does to understand why it's making it miss.
the only thing i dont understand with this egr assumption is why would it effect only one cylinder and the same one 100% of the time.
Should it be the egr ports don't be tempted to bypass the system, unless you love spark knock.
just cleaned it, 3 where completely clogged and one was about halfway clogged, which was cylinder 1. so we'll see in the morning what the verdict is.
revvin9k
11-08-2004 12:45 PM
