computer diagnostic plug in..... where? - Honda-Tech
Old 03-25-2015, 12:04 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Old 09-09-2007, 07:51 PM   #1
kirbyman's Avatar
Default computer diagnostic plug in..... where?
My friend has a 97 honda accord.. he has a check engine light that keeps coming on, and we can't find where to plug in the diagnostic computer.. anyone got ideas? we checked all over the cab, under the hood, everywhere.. thanks much
kirbyman is offline   Reply With Quote
Old 09-09-2007, 08:28 PM   #2
rival12's Avatar
Default Re: computer diagnostic plug in..... where? (kirbyman)
http://www.obddiagnostics.com/FAQ.html#15
Typically most diagnostic computers aren't readily available for OBD-1. If you have an OBD-2 that's a different story.
As for checking engine codes...
if you take a look under the glove box, you should find a blue connector, disconnect it.
take a small piece of wire...a couples inches or so...
stick it where the connector goes into (the female part)
it will make a closed loop (in the female adapter)
turn the key into the on position, and count the engine light blinks.
short blip = 1
long blip = 10
it will cycle through all the engine codes, and then it restarts
there is typically a short pause between codes, and it will have a long blink first if the code is above 10.
i.e. long long short = 21
use the search feature (the red search at the top right of this site) to understand what each code means. goodluck
rival12 is offline   Reply With Quote
Old 09-09-2007, 08:33 PM   #3
rival12's Avatar
Default Re: computer diagnostic plug in..... where? (rival12)
Old 09-10-2007, 03:23 AM   #4
kirbyman's Avatar
wow.. thanks.. i was hoping that his car wasn't the one you had to do that to... but ohwell.. i thought after 1996 all cars were required to be obdII
Old 09-10-2007, 05:20 AM   #5
H-T Order of Merit
TouringAccord's Avatar
no, you do not jumper the service connector and count the flashes on this car. 96 and up are ODB2 which require a scan tool.
as for where to plug it into, sorry, I'm not exactly sure where the connector is located on the 97 Accord. If I had to guess though I would say under the dash on the driver side somewhere.
If you cant find it, just go up to a local AutoZone, or another place, and have them check it for free. Or you could call AutoZone and ask them where it's at if you already have a scan tool.
TouringAccord is offline   Reply With Quote
Old 09-10-2007, 06:25 AM   #6
devilpuppy's Avatar
the connection point is behind the ash tray!
right infront of the shifter and beside the cig. lighter....just pull the ash tray out and look inside...u will see the connection point
devilpuppy is offline   Reply With Quote
Old 09-10-2007, 06:38 AM   #7
GhostAccord's Avatar
Default Re: (devilpuppy)
Just pull out the ashtray and you will see the Diagnostics port.
FYI - You can jumper the service connector as mentioned above on an OBD2 Accord. I have done it many times on my 96 EX. If there is a difference between the 96 & 97's then it may not work. But I know that an OBD2a can be diagnosed using the jumper method.
GhostAccord is offline   Reply With Quote
Old 09-10-2007, 06:52 AM   #8
H-T Order of Merit
Default Re: (GhostAccord)
Quote:
really... I didn't know that. good to know
Old 09-10-2007, 07:30 AM   #9
kirbyman's Avatar
Default Re: (TouringAccord)
Quote:
Thanks!
Quote:
we both work at advance, and hes the manager... :-/ how bad is that?
jumping diagnostic connector on a 92 honda accord rastaman420 Honda Accord (1990 - 2002) 2 03-02-2013 06:59 PM
DIAGNOSTIC PLUG???? frokido K Series 3 04-21-2010 12:42 PM
ecu harness problem jkinros Honda Civic / Del Sol (1992 - 2000) 8 05-24-2008 10:03 AM
Diagnostic Plug for OBD2A K I T T Honda Civic / Del Sol (1992 - 2000) 2 12-08-2007 05:07 AM
diagnostics port pizzamanprelude Honda Prelude 6 07-05-2006 01:39 AM
Tags
1994, 2002, 96, accord, acura, adapter, cd5, computer, diagnostic, honda, plug, point, scan, tl, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
